ps belt
Old May 27, 2004 | 03:57 PM
Mike banX's Avatar
Default ps belt
how do i put a ps belt on my b18, the belt is to short for the distance from the pump pulley to the crank pulley, is there a way to adjust the pump pulley to bring it in clocer or something like that
Old May 28, 2004 | 12:35 AM
kickerx's Avatar
Default Re: ps belt (Mike banX)
ya you loosen the ps pump adjusting bolts to make it closer to the crank pulley...
Old May 28, 2004 | 04:13 AM
Mike banX's Avatar
which bolts are the adjusting bolts
Old May 28, 2004 | 05:26 AM
JimBlake's Avatar
Default Re: (Mike banX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike banX &raquo;</TD></TR><TR><TD CLASS="quote">which bolts are the adjusting bolts</TD></TR></TABLE>On mine, the 2 mounting bolts are in long slotted holes. Loosen them just enough so the entire pump can slide on it's mounting bracket.
Then there's a long skinny bolt up top, with a head like a wing-nut. When you unscrew that, it lets the pump slide down so you put the belt on. Tighten it to tension the belt, then tighten the mounting bolts.
Old May 28, 2004 | 06:46 AM
dfoxengr's Avatar
Default Re: (JimBlake)
just look on the braclet at which bolts hold the pump on.
mrfootball420
Aug 30, 2009 05:42 PM
pjr710
Apr 3, 2009 02:48 PM
megalomaniac001
Honda S2000
Jan 5, 2009 04:08 AM
Mike banX
May 28, 2004 05:01 AM
.RJ
Jun 18, 2003 10:57 PM
