old topic, new question: bouncing speedo
Old May 27, 2004 | 12:27 PM
kaj's Avatar
kaj
Default old topic, new question: bouncing speedo
hey, time to bring back a dead topic
my speedo was working fine... then, i swap distributors and now it's bouncing like crazy.
my friend's speedo did this before his dist went out. coincidence??
Old May 28, 2004 | 08:07 AM
Ekasey's Avatar
Default Re: old topic, new question: bouncing speedo (kaj)
dizzy shouldn't be the cause
your sppeed sensor which is where your speedo gets it's reference from is on the back on the transmission check there for corrosion.
Old May 29, 2004 | 04:20 PM
kaj's Avatar
kaj
Default Re: old topic, new question: bouncing speedo (eLusive ek4)
shouldn't
but, i switched dist and my speedo needle would bounce. not go to 0, then back.. go to 0 then back up.. but would jump form the 40mph i'm doing on up to 80 or more. like something was spiking. then i would get a CEL with no code.
switch back to old dist, problem fixed.
switch BACK and needle is bouncing again.
anyone?
is it possible a JDM motor/dist doesn't like a USDM ecu?? we're going through distributors on a regular basis.
B_Swapped93
Oct 2, 2014 05:39 PM
ufakeit
10
Sep 8, 2009 05:34 PM
nnmewes
May 10, 2009 12:39 PM
Bejita
11
Jan 23, 2007 12:23 AM
Just Checking In
23
Jul 6, 2003 09:45 AM
