Aftermarket parts for JDM ZC
Old May 27, 2004 | 12:21 PM
hahahahhah's Avatar
Default Aftermarket parts for JDM ZC
Just looking around for aftermarket parts on a JDM ZC (going into an 89 CRX Si) and I can't really find anything. Are there true-built aftermarket parts for the ZC? Or is there anything that would be compatible with that engine (aftermarket parts for a 90-91 Integra?). I'm looking specifically for headers, cams, etc.
Thanks,
-edmCRX
Old May 27, 2004 | 01:35 PM
Mleach's Avatar
Default Re: Aftermarket parts for JDM ZC (edmCRX)
search for DOHC in this forum, it has been discussed a number of times.
Old May 27, 2004 | 02:16 PM
DJ_SaNdOz's Avatar
Default Re: Aftermarket parts for JDM ZC (Mleach)
any d series header should work out ok from 88-00, you'll just have to port the header near the flange by taking the exhaust mani gasket from an 89 teg & marking that against the flange & then dremel it smooth so it matches. (I hope that made sense). For cams Exospeed sells regrinds, soyou would need to either take yours out of teh motor & send them to Exospeed, or purchase a set of used stock cams to send off. I am not aware of any place that sells new billit cams for teh ZC, other than some HKS turbo cams that are serious $$$$$$. HTH
Old May 27, 2004 | 05:25 PM
hahahahhah's Avatar
Default Re: Aftermarket parts for JDM ZC (DJ_SaNdOz)
Thanks for the replies, anyone else know anything about this topic?
Old May 28, 2004 | 09:07 AM
ExospeedAMcrx's Avatar
there's plenty of things that we can do to the ZC motor.
we have 2 stages of our own grind of camshafts. one is streetable/race cam. great power but not too aggressive that its high maintenances. and our more aggresive cam which has a slightly lopier idle for the more aggressive setup.
for headwork, we do have port n polish work with valvetrain upgrade.
PetersonJ39
Mar 31, 2011 01:33 PM
firstgenrex
Sep 5, 2003 07:22 AM
sabertooth
Sep 1, 2003 04:44 PM
Little_Blu
Mar 19, 2003 01:59 PM
