if i get a ZC and Turbo engine in a 88 crx will I need new engine mounts
Old May 27, 2004 | 11:50 AM
zczac's Avatar
Default if i get a ZC and Turbo engine in a 88 crx will I need new engine mounts????? anyone
will I need them and if I do how much will that cost me and if I get that engine and the turbo kit will I need to get a better Tranny
Modified by zczac at 9:04 PM 5/27/2004
Old May 27, 2004 | 12:23 PM
manson's Avatar
Default Re: if i get a ZC and Turbo engine in a 88 crx will I need new engine mounts????? anyone (zczac)
no you won't need mounts... the ZC is a bolt in. as for the tranny i don't know what your options are.
Old May 27, 2004 | 12:58 PM
EL Vap133's Avatar
You can use a ZC or Si tranny.
Old May 27, 2004 | 01:18 PM
MooreBoost's Avatar
Default Re: if i get a ZC and Turbo engine in a 88 crx will I need new engine mounts????? anyone (EL Vap133)
I use an Si, works well.
Old May 27, 2004 | 02:06 PM
4drEF's Avatar
Keyboard Humorist
For turbo it wouldn't be a bad idea to use the ZC tranny. It uses an intermediate shaft much like the B-series engines do. This helps reduces torque steer which is common in car that have one axle that is noticable shorter than the other. You can even find ZC tranny's with LSD. LSD and less torque steer will be nice additions to a big' powa' turbo ZC!
Si tranny will work fine though... cheaper too.
Old May 27, 2004 | 02:11 PM
DJ_SaNdOz's Avatar
Default Re: if i get a ZC and Turbo engine in a 88 crx will I need new engine mounts????? anyone (4drEF)
new mounts don't cost that much for stock replacements, so you may as well do it while the motors out.
93accordsleeper
Sep 27, 2006 09:03 AM
91 ZC hatchback
Dec 26, 2005 08:34 AM
quik1
Nov 18, 2005 04:51 PM
vtec_head
Apr 18, 2002 10:33 AM
honduh-guy
Feb 26, 2002 09:19 AM
