88 crx suspension possible to swith to 89-91?
I was told 88 crx all hf,dx,si have a suspension similar to a type r? is it possible to convert the suspension to a 89-91 I got all 89-91 suspension parts 4 wheel teg disc brakes etc. and was wondering if it will all work for an 88 crx si, I would swap it off my 89 crx hf. just curious????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">All you have to do is get 89-91 LCAs and 89-91 shocks.
For the front brakes, use your stock upper arms. </TD></TR></TABLE>
Exactly what he said. Only thing is that the front shocks are the same 88-91 the rears you would have to use any 89-95 civic or 89-91 crx shocks ( same part #'s). You may also need the brake line that comes on the integra for its disc brakes. The hydraulic line that go from the body along the trailing arm to the caliper. You may be able to make the stock ebrake cables work.
88CRX951
17
Jul 13, 2008 04:07 PM
The DX Rex
Nov 22, 2004 12:14 PM
HondaRcB
Mar 15, 2003 06:42 PM
