clutch problems
Old May 27, 2004 | 07:39 AM
bloodyknuckles's Avatar
Default clutch problems
i drive a 88 crx dx. the clutch was slipping horribly, so i ordered a new oem exedy clutch from clutchcityonline.com. i replaced the clutch. every thing seemed fine until i put the car back together and tried to get the car into gear. the clutch wouldnt disengage. everything is moving, the clutch arm and all,but i cant get it into gear. we adjusted the clutch cable as far as it would go and it didnt help at all. the only problems i can think of are: wrong pressure plate, bad pressure plate, or stretched clutch cable, but i dont think that its the clutch cable. does any one out there have any ideas before i take the car apart and send back the clutch plate and pressure plate? thanks in advance for any info or advice you can give me.
Old May 27, 2004 | 08:52 AM
EL Vap133's Avatar
Default Re: clutch problems (bloodyknuckles)
When you ordered the clutch, did you specify that you had an 88?
Old May 27, 2004 | 09:01 AM
5litereater's Avatar
Default Re: clutch problems (EL Vap133)
hmmmm. make sure ur clutch cable isnt caught up on anything in your motor bay (which could stop it from moving freely). if all else fails call exedt and say wtf, they should have an answer for you. good luck.
Old May 27, 2004 | 04:52 PM
Default Re: clutch problems (5litereater)
yea i specified that i had a 88.
i dont think the cable is gettin caught on anything, but i will check in the moring.
i did call clutchcityonline and they told me to take the clutch out and send it back and they would send me a new one. but thats easier said then done.
thanks again
Old Jun 1, 2004 | 03:46 AM
yeah putting a tranny on a motor thats already in the car sucks. bastards...
Old Jun 4, 2004 | 07:26 PM
93Civac's Avatar
Did you replace the throw out bearing, and did you make sure it was attached to the arm?
88 EF Hatch
Transmission & Drivetrain
Oct 24, 2009 04:07 PM
88 EF Hatch
18
Oct 24, 2009 04:06 PM
MichealSenior
Feb 17, 2009 12:56 AM
SOUTHCREX
Apr 11, 2005 08:51 AM
USDM 4G VTEC
Jun 20, 2003 05:20 PM
