Are these Really ITR Cams [98 spec] - *pix*
hey guys, just wanted your help to see if this is in fact an 97-98 USDM ITR spec Intake cam..
here are the enclosed pix..
Also how does the wear look on the camshaft itself, pretty normal stuff??
thanks
Navin
-wh0 is hoping it is infact an ITR intake cam
thanks
Navin
I believe they are GSR cams - see
https://honda-tech.com/zerothread?id=780438
https://honda-tech.com/zerothread?id=820690
see here (2nd post) for what ITR (96/97-99 & 00+)cams look like
https://honda-tech.com/zerothread?id=821143
next time search - "identify cam" topics have been posted before
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAredteg »</TD></TR><TR><TD CLASS="quote">not to sure but i think the r's have 2 lines going around the end instead of 1</TD></TR></TABLE>
yeah they have 2 engraved rings but ONLY on '00+ ITR cams...see the third link in my post above. He clearly states his are '98 spec
Please note the protruding rings (just below the engraved rings) -- the 97-99 has two protruding rings - spaced apart. while GSR cams have three protruding rings (see my links 1 & 2) that match his pic. I am not 100% positive they are GSR cams since nobody has been able to determine with proof ALL 97-99 USDM ITR cams look like that. I will create a thread in the ITR forum - after I search thoroughly
edit - after my searching it appears if your cam has the three protruding rings & one engraved that its a GSR cam - sorry
Modified by adirondackR at 12:08 PM 5/27/2004
shabam
Apr 27, 2007 01:02 PM
