break problems! need help
Old May 26, 2004 | 07:04 PM
hi mom's Avatar
Default break problems! need help
Alright, well I ordered my tires and everything, and I have my first autocross event (track event) this weekend MAY29TH, and my caliper had seized a week before. Today I finally got a chance to get the new one and put it on, did everything as planned and in order, then took it for a drive. Well when I press on the brake, the piston comes out like it should, but it seems to recess too far back in when you let go, which is making the pedal go way to far down just to grab. When it grabs it grabs hard, but it just seems like it has to travel much farther then normal. Any suggestions to get me on the road and out to this event Saturday??
Also.. the e-brake is not fully tightened, would that make the pedal such a further distance before engaging?
Ive been told there is a spring in the back of the piston that is probibly pulling it back??
Also I bled the single line from the caliper that I changed, I never did the other 3, would that have done it?
EDIT: I always spell break not brake..jeese! haha
Old May 27, 2004 | 04:49 AM
hi mom's Avatar
Default Re: break problems! need help (Kid RS)
Old May 27, 2004 | 06:29 AM
Farmer Brown's Avatar
Are you using stock calipers? I've never heard of that problem, interesting...
Old May 27, 2004 | 07:40 AM
Rtype16's Avatar
Default Re: break problems! need help (Djaric)
Re-bleed the entire brake system.
Old May 27, 2004 | 11:22 AM
hi mom's Avatar
Default Re: break problems! need help (Rtype16)
Alright, Im gona try and bleed them all again..
Old May 27, 2004 | 03:04 PM
DBZ's Avatar
DBZ
make sure u bleed farthest to closest from the m/c
Old May 28, 2004 | 12:38 AM
kickerx's Avatar
bleeed the entire system and replace with fresh brake fluid. good to replace fluid from time to time.
nickhans
Apr 30, 2007 12:08 PM
hi mom
May 26, 2004 06:15 PM
MagicCivic
Mar 12, 2003 05:18 PM
.RJ
15
Oct 27, 2002 05:18 AM
XR4racer
Aug 12, 2002 10:57 AM
