Two MPFI swap questions. Please Help :)
Question 1: What side is the "right" side when im looking at the injectors? I am using this as my guide, http://www.fourthgenhatch.com/index2.html So if i am standing out side the car and looking at the injectors which side is the "right" side? Because he might have written the guide like he were sitting in the drivers seat right?
Question 2: I have a CRX Si resistor box and there are the four black wires coming out right? My dad and I figure that it is the power for the injectors right? But there is a red wire too, I figure that this must be the power to the box right? Well where do we run the power wire to?
Thanks in advance for any and all help. Have a good night.
Injectors 4-1
Yellow Blue Red Brown T-Belt side
The 4 black wires go to the ywllow/black wires on the injectors. The red wire goes to the 2 yellow/black wires you cut from the old injectors.
Ok I found the two injector wires I need. But there seems to be somthing alittle off. The size of the wire is diffrent. The brown plug has bigger gauge wire in it. Is that alright? Do I just solder the yellow with a black strip wire from the green plug with the same colored wire from the brown plug? We are just worried that it might mess somthing up because the wires are diffrent gauges. Thanks in advance for the help.
Jeramy
Jeramy
When talking about an engine part locations right side is the driver side left side is the passenger, as if you were standing in front of the car looking at the engine. Everything else on a car you do it like you were sitting inside it.
i heart honda
Feb 14, 2009 03:46 PM
SiMateoAko
Jun 9, 2006 10:27 PM
b16awarrior
13
Sep 17, 2002 02:36 PM
