My dad put P/S fluid instead brake fluid
Old May 26, 2004 | 06:33 PM
SilverDc2's Avatar
Default My dad put P/S fluid instead brake fluid
i hardly work on my with my dad around, i needed a litle bit of brake fluid and a little bit of p/s fluid on my car..i went inside the house to get a drink i see him pouring p/s fluid where your supposed to put brake fluid!! he got them mixed up...
drain the system..??
or isn't so small insignificant that it wont matter.??
Old May 26, 2004 | 06:51 PM
tilt's Avatar
Default Re: My dad put P/S fluid instead brake fluid (SilverDc2)
suck it out with a baster. use paper towels to get the rest out.
Old May 26, 2004 | 06:58 PM
ozzyman's Avatar
Default Re: My dad put P/S fluid instead brake fluid (tilt)
You need to flush your system. I most definately wouldnt risk leaving PS fluid in my brake resevoir. Safety comes first IMO. You never know what might happen. Did he put brake fluid in the PS resevoir too??
Old May 26, 2004 | 08:01 PM
Frankintegra's Avatar
You got to drain, flush and fill . You should not have to add no brake fluid to the brake reservoir. As you brakes wear the fluid will reduce then when you put on new brake pad the fluid will go back up to the top! Replace the fluid back to were it was and keep your dad out of your engine!
Of topic but my sister in-law had a gas station attendant add engine oil to the auto transmission and hence had no oil in the engine and bye bye enigine.
Old Jun 6, 2004 | 02:32 PM
IVI's Avatar
IVI
Default Re: My dad put P/S fluid instead brake fluid (Frankintegra)
sucking it out of the master should be good enough.
just to be on the safe side, i would flush and refill.
Old Jun 6, 2004 | 02:54 PM
Fuuma0083's Avatar
Default Re: My dad put P/S fluid instead brake fluid (IVI)
PS fluid in brakes
it makes all rubber seals and line swell up
hopefully it hasn't been pumped through yet.
Stripped Honda's Avatar
99-0104
does anyone know the effects of doing this to your brake system ?
i do i had a customer come in with this problem but for him it was too late and we had to change the master cylnder proporton valve calipers and wheel cylnders ....
when the two fluids mix they expand causing the brakes to always be applied and tears up all the rubber parts in the brake system
i would do asothers have said and suck it out right away and flush your brake system with at least 2 big bottles of brake fluid
Old Jun 6, 2004 | 08:54 PM
letmeseeyouskip's Avatar
damn that some serious ****
Corksil
Jun 28, 2011 02:24 PM
DC4R27
Dec 2, 2009 10:03 AM
bopbop93030
May 9, 2008 07:01 PM
Tad
Jun 18, 2005 07:59 PM
kommon_sense
Jan 4, 2005 11:46 AM
