obd2 to obd1 conversion, is it worth it?
It depends on what your going to so to it. If your just gonna put basic bolt ons on it then dont bother. But if your gonna tune the **** outta it then it'll be easier to get the OBD1 conversion done so u can use Hondata. You can also use the EMS too but ionno if u have to convert to OBD1 to use that, i think its OBD2 compatable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legendaryyaj »</TD></TR><TR><TD CLASS="quote">You can also use the EMS too but ionno if u have to convert to OBD1 to use that, i think its OBD2 compatable.</TD></TR></TABLE>
AEM EMS will swap right into OBD2 wiring - no need for OBD1 swap
fyi, this isn't merely a conversion harness on the chassis harness, and then an obd1 ecu...first of all, the obd2 distributor will not work with the obd1 ecu...you will need to wire in the correct distributor wires and use an obd1 distributor...it's more of a headache than it's worth, and obd2 really isn't that bad...
brotech
Dec 20, 2005 08:02 AM
Honda-Hooligan
Aug 13, 2003 05:53 PM
1020, accord, aem, combercion, conversion, convert, converting, distributor, honda, ob1, ob2, obd, obd1, obd2, worth
you will be glad you did.
