15" or 16" SW388? Will 15" SW388 clear Spoon calipers?
Old May 26, 2004 | 04:31 PM
ITRFetish2000
Guest
Posts: n/a
Default 15" or 16" SW388? Will 15" SW388 clear Spoon calipers?
For you guys with SW388's on your R's, what would you prefer....price not being a determining factor. 15 or 16 in. wheels? Also, how to do keep the guys at the tire mounting place from screwing up your 450$+ dollar wheel when it is time to get new rubber?
Old May 26, 2004 | 05:27 PM
igyloo's Avatar
Default Re: 15" or 16" SW388? Can you use Spoon four pot on 15" SW388? (ITRFetish2000)
https://honda-tech.com/zerothread?id=191550
i think you need to trust the tire place you go to...unless of course you mount tires yourself
Old May 26, 2004 | 05:36 PM
R.S.'s Avatar
Default Re: 15" or 16" SW388? Can you use Spoon four pot on 15" SW388? (igyloo)
depends on what u plan on doin to your brakes, if your gona go w/ bigger brakes that require 16"+ get 16".....otherwize get 15"
Old May 26, 2004 | 06:01 PM
igyloo's Avatar
Default Re: 15" or 16" SW388? Can you use Spoon four pot on 15" SW388? (R-Spec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-Spec &raquo;</TD></TR><TR><TD CLASS="quote">depends on what u plan on doin to your brakes, if your gona go w/ bigger brakes that require 16"+ get 16".....otherwize get 15"</TD></TR></TABLE>
looks like he's asking about Spoon Brakes
Old May 26, 2004 | 06:15 PM
R.S.'s Avatar
oh didn't see the edited title...
Old May 26, 2004 | 09:47 PM
eg_type_r93's Avatar
i belive you can use the spoon calipers with 15 inch spoon rims
Old May 26, 2004 | 10:10 PM
yellow blur's Avatar
Default Re: 15" or 16" SW388? Can you use Spoon four pot on 15" SW388? (eg_type_r93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 &raquo;</TD></TR><TR><TD CLASS="quote">i belive you can use the spoon calipers with 15 inch spoon rims</TD></TR></TABLE>
No you cannot. Only 16" SW388's will clear the Spoon Calipers.
Old May 26, 2004 | 10:11 PM
B2FiNiTY's Avatar
Default Re: 15" or 16" SW388? Can you use Spoon four pot on 15" SW388? (yellow blur)
You can only run the 15 inch spoon rims with spoon calipers if you run a spacer.
16 inch fit with no clearance problems.
Old May 26, 2004 | 11:09 PM
nightrider's Avatar
if you're just contimplating what size rim regardless of calipers, 15's tires are cheaper. i believe all this stuff has been in the archived posts.
Old May 27, 2004 | 06:12 AM
George Knighton's Avatar
H-T Order of Merit
Default Re: 15" or 16" SW388? Will 15" SW388 clear Spoon calipers? (ITRFetish2000)
Another vote for 16" here. If you're getting Spoon calipers, you realy don't have a choice, but the 16's are better for the extra 1/2" of width, anyway, IMHO.
marcdem86
Jun 30, 2009 09:40 AM
tomman2001
Nov 1, 2007 04:59 AM
K20EF8
14
Oct 18, 2006 03:20 PM
B2FiNiTY
Apr 22, 2002 02:32 PM
jeff652
Sep 20, 2001 01:23 PM
