kteller.com exhaust kit question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX »</TD></TR><TR><TD CLASS="quote">http://www.kteller.com sells mandrel bent kits for the crx for $185 for the piping. It's slip fit, so you can put it together with clamps or have it welded.
I've heard good things about him and his stuff, and I will probably order it when it comes time to do the exhaust on my swap.</TD></TR></TABLE>
I was wondering if the kteller.com piping kits need a cat or if I can just run straight pipe all the way from the end of my header to my muffler? Anyone have an experience with these kits (1989 CRX Si to be exact)?
Thanks,
-edmCRX
Thanks,
-edmCRX
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
the kit comes with enough piping to run without a cat. everything is a slip-on, the only thing needs to be done is welding the hangers and flaring the header flange.
stan
stan
Sounds good.. another quick question..
What kind of aftermarket headers are available for the ZC? Is there any kind of header out there that comes relativley close and can be port matched?
Thanks.
Thanks.
I have 00ex dc sports header on my zc. The ports are alot bigger than the stock d15 manifold I was using. With the header only one port did not line up, it was pretty close though. I am also ordering my exhaust for KTeller burt his website does not list mild-steel for crx so I am waiting for email.
atarigamer01
Nov 6, 2008 04:35 PM
