FS: Civic hatchback - HC H1 or HPDE car
The car is now being parted out...
Details can be found here for now:
http://www.carolinahondas.com/...37825
I will make a thread on H-T when I finish taking all of the pictures (probably Thursday).
CLICK HERE FOR MORE PICTURES <-- the first pictures in the gallery are the most current.
Well, my spending habits have finally forced me to sell this car. I was always too focused on spending money on the car and forgot about the driving part... Below is a partial list of the parts I have sitting around. I will update it as I find more items. Initially, I am looking for a buyer for the car and at least one engine. If you're a serious buyer (you have 12-20k in hand), contact me and we can work out the specifics.
The car will eventually be parted out if no buyer comes forward. I do not really want to start parting things right now though.
Remember, the parts list is just a list of parts... and is flexible.
Shell
1992 Honda Civic CX
- no rust, never wrecked, only a few door dings
- full welded cage – painted and padded
- integra front subframe
- integra steering rack (not powered)
- integra type r MC/booster 4040 proportioning valve
- integra suspension arms with GSR brakes
- integra type r rear lca’s
- Goodridge stainless brake lines
- full ES bushing set
- GSR 24mm front sway bar
- Comptech 22mm rear swaybar/tiebar combo
- Fluidyne aluminum integra radiator
- Advance Design double-adjustable shocks (valving is for 600-900 front and 700-1000 rear *ballpark estimate – two events since rebuild and revalve)
- 2.5” mandrel exhaust with Magnaflow mufflers
- keylock removed – car starts with a longacre ignition switch
- Skunk2 front upper control arms
- Skunk2 front upper strut bar
interior
- two sparco evo2 seats
- **note** seat mounts have been welded into place. Unless you are tall you will need to have the driver’s seat relocated to fit you.
- two sparco 5-point harnesses (about to run out of SFI dating)
- Momo MOD07 steering wheel
- Momo steering hub
- LTB steering quick-release
- Apex’i tachometer
- **note** because of the location of the dash-bar the gauge cluster cannot be mounted in the factory location (but the wiring is still in-tact)
- window-net with mounting (upper mount installed, lower needs to be fabricated)
- heater core and blower are still installed -- heater only blows in defrost position
- passenger window still installed
- driver's window is gone
Engine #1
B18C5 engine built to World Challenge specs
- Carillo Rods
- .010 over JE Pistons 11.5 to 1
- polished and balanced crank
- ported head
- Skunk2 titanium retainers
- Skunk2 valve springs
- Skunk2 stage 2 cams
- Skunk2 cam gears
- MBE 914 stand-alone ECU
- one event since build
Engine #2
- B18C block
- balanced rotating assembly
- GSR rods
- CTR oversized pistons
- Alaniz ported ITR head
- Alaniz valve springs and titanium retainers
- Toda VTEC killer camshafts
- Unorthodox Racing Ultra T cam gears
- engine assembled by RLZ engineering
- 0 miles since assembly (never turned over)
Transmission Parts
- ITR transmission
--- 4.7 final drive
--- ATS differential – two events since complete rebuild by A-T-S USA
--- absolutely perfect condition
- *possibly for sale* ITR transmission – brand new from Acura
- *possibly for sale* 1998 GSR transmission – low miles
- Toda Flywheel – brand new
- Clutchmasters Stg3 clutch – one event
- Clutchmasters aluminum flywheel – one event
Misc Parts
- Toda Header
- Custom-built extended-length header
- Mugen Intake
- Kosei K1-S 15x7 wheels with Kumho MX tires
- SSR Competition 15x7 wheels with Kumho V700 tires
- wide-view mirror (not installed)
- 6-pole battery kill switch
- Mugen baffled oil pan
- AEM EMS standalone ECU
- AEM EMS UEGO wideband O2 sensor
- Suspension Techinques rear toe adjustment arms (spherical bearings)
- rear ITR lca’s with monoballs (spherical bearings installed)
- front ITR lca’s with monoballs (spherical bearings installed)
- AP Racing front brake kit $$$$ (fits under some 15” wheels)
Serious inquiries can be sent to jsnavely@nc.rr.com - the car is located in Raleigh, NC.
Modified by JeffS at 9:40 AM 6/17/2004
Modified by JeffS at 9:43 PM 6/23/2004
Shell
1992 Honda Civic CX
interior
- Momo steering hub
- Apex’i tachometer
Engine #1
- Carillo Rods
- ported head
- Skunk2 cam gears
Engine #2
- B18C block
- GSR rods
Transmission Parts
- ITR transmission
--- 4.7 final drive
Misc Parts
- Toda Header
- Mugen Intake
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy »</TD></TR><TR><TD CLASS="quote">Out of curiousity, would you sell any of the parts separate from the car?</TD></TR></TABLE>
Yes, I suppose it will eventually be parted out. I will probably wait a couple weeks before doing that though.
It might help to supply a itemized list in a spreadsheet format of how much each component costs new and the % of life left on the part.
I recently purchased a similar set up car and that was helpfull, I'd be interested in some parts for future racing if you can't get it sold altogether.
Thx guys...
This was a spur of the moment decision - brought on by an impeding job change. I just thought I'd throw it up to let people know it was available.
I'll work on getting some more detail on the parts - though I'm still not ready to part it out.
How much do you want for the mugen intake? email me at jpb105079@yahoo.com
I need a B-Series Trans for a B18B swap going in my EG. What would you like to get for any of the three transmissions you have.
Thanks
Thanks
I've decided to part the car out.
I have kept track of everyone who contacted me and I'll let you know when I get the for sale post up... hopefully tomorrow if I can finish taking pictures of everything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITC Racer »</TD></TR><TR><TD CLASS="quote">How tough would it be to put back to CX specs (for ITC)? Do you have the original engine/trans/suspension?
Thanks</TD></TR></TABLE>
I do not have any original parts for the car.
You would have to change:
- rear control arms
- rear trailing arms
- rear brakes
- front knuckes
- front brakes
- front subframe
- steering rack
- brake MC and booster
My first thought was that it's not worth it. Then again... you could probably get the needed parts for free (including the engine/trans - which I do not have), or next to it, and make a decent amount off the integra parts you were replacing. That's a lot of work though.
- rear control arms
- rear brakes
- front knuckes
- front brakes
- front subframe
- steering rack
Thx Karl... I'm really hoping a H-C racer wants my H1 engine... I don't know who I'd sell it to otherwise.
Here's a link to the "parting out" info:
I'll create a thread on H-T when I finish taking all the pictures.
BTW... I can still do a package deal if anyone's interested.
Regarding the engines -- I'll be a little more flexible on their pricing than I can be on the smaller parts.
And the shell... I'm not sure what a fair price is. I picked a price less than what I have in it and I'll go from there.
g2turbo
Feb 15, 2015 09:38 PM
