QUICK ? PLEASE HELP
will these plugs http://cgi.ebay.com/ebaymotors...WN:ITwork with this headhttp://cgi.ebay.com/ebaymotors...WN:ITand will i need a injector box
im doing a mpfi swap right now i have a dpfi 89 hatch but i bought the head and wiring hraness in the links i posted im just wondring if i need a resitor box, i was told since it is a 95 head i wont
Contact member "Nikitad", he really knows his ZC/sohc stuff. I believe you're gonna have to modify the harness, he can do that for you as well.
Ok.... you are going to have OBD1 injectors and OBD0 injector clips, which is not a problem. Just take a sharp screw driver and gouge out the little plastic parts in the top corners of the injector where the clip connects. I've done this before when dropping Z6's into EF MPFI cars. Also, don't worry about needing an injector resistor box, those injectors don't require one. Just solder all the wires that would have gone to the injector resistor box together (5 of them) and you're done.
