About to wire up fuel pump kill switch....
and I wanna make sure that I cut the right wire. IT is yellow wire with a green stripe right? I am not doing this at the fuel pump, but along the door sil. It runs along the driver side right. thanks. BTW I searched cuz this was answered in a thread but I cannot find it.
i just did this last weekend, using the wire at the driverside door. You want the YELLOW wire with GREEN stripe. I believe there is only one other yellow wire in the bunch, and it has no green on it whatsoever. If you could take better pics without the flash i could tell you if it was correct. But really you cant mess it up as there is only 2 yellow wires and only 1 has a green stripe. Good luck and make sure you disconnect your battery.
Here is a site if you dont know about it already. http://www.courtlukens.com/cutoff_switch.htm
Yea the wire just seemed really thin, and people were talking bout two different yellow with green strip wires and they should use the bigger one. Thanks for the help.
the fuel pump is negatively switched, so yeah cut the hot wire.
good idea to cut it along the door sill instead of under the back seat. i want to remove it but i don't want those wires to be visible. now i have something to do today
FragSyndrome
Apr 7, 2004 01:54 PM
JLange
Audio / Security / Video
Jan 2, 2003 01:24 PM
VTECAcuraGSR
Apr 10, 2002 12:04 PM
