brake caliper dilema (retaining clips)
Old May 26, 2004 | 11:32 AM
crxgator's Avatar
Default brake caliper dilema (retaining clips)
ok so i bought a set of rebuilt calipers on ebay last year and the part number on the calipers match up to the part number on the stock ones. the problem is that the retaining clip doesnt fit since the hole on the new calipers is smaller compared to the stock ones...what retaining clip can i use? do i need to actually use it or will i be fine without it?
Old May 26, 2004 | 01:58 PM
IVI's Avatar
IVI
Default Re: brake caliper dilema (crxgator)
what retaining clip are you talking about?
Old May 26, 2004 | 02:00 PM
crxgator's Avatar
Default Re: brake caliper dilema (IVI)
that brand new silver shinning one...
Old May 26, 2004 | 02:32 PM
IVI's Avatar
IVI
can you describe how it doesnt fit? if its just the edges just file them down a little bit, and yes you do need those.
Old May 26, 2004 | 02:33 PM
crxgator's Avatar
the middle part wont fit in the hole that is cut away on the caliper...
Old May 26, 2004 | 02:39 PM
IVI's Avatar
IVI
thats really odd... where did u get the new ones from?
Old May 26, 2004 | 02:48 PM
Dan GSR's Avatar
its good to have them, pads wil move around without them
IVI's Avatar
IVI
okay i think i know whats going on... those model numbers : 17CL14VN can be for diffrent cars.
I think they are mostly for honda preludes.
Old May 26, 2004 | 04:54 PM
crxgator's Avatar
they are for integras, they bolt up to the 92 integra knuckle/bracket i have bought...
Old May 26, 2004 | 05:00 PM
hi mom's Avatar
yeah, you should use them. they keep the pad from moving around, just a lot safer..
Old May 26, 2004 | 05:11 PM
crxgator's Avatar
Default Re: brake caliper dilema (Kid RS)
ok but where do i get them for mine? has anyone here changed brake pads before on like a 94+ integra? cause i want to know if their caliper has a small hole like mine...autozone didnt have any for me to check out so i cant see if they are difference in the DA calipers like i have and my new ones...
Old May 26, 2004 | 06:11 PM
..::91TEG-G2::..'s Avatar
why dont you get a file and file it wider? or get a dremel tool or barrow one from someone, or get a sanding bid for a drill and sand it yourself.. not that hard
Old May 26, 2004 | 06:14 PM
Default Re: brake caliper dilema (..::91TEG-G2::..)
oh, and if they re-coated the caliper with that blk stuff.. then it could of just made that spot a little bit wider then stock/origional, so you can sand that down some too.. if u dont wanna make the slots on the metal peice wider
Old May 26, 2004 | 06:48 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">why dont you get a file and file it wider? or get a dremel tool or barrow one from someone, or get a sanding bid for a drill and sand it yourself.. not that hard</TD></TR></TABLE>
your ******* kidding me...you want me to file thick *** metal...
i painted the calipers, its not paint its metal...
Old May 26, 2004 | 06:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">
i painted the calipers, its not paint its metal...</TD></TR></TABLE>
well yeah.. lol.. its not that hard man, if u just work on both sides of it.. or file the retaining clip.. its not that hard with a dremel or a sanding tip on a drill
crxgator's Avatar
well i was pointed in the right direction and was told they are 94+ integra calipers and to get the clips for them...
i thought 90-00 were considered the same since rotors are the same...
br'Y'an
May 11, 2007 08:24 AM
RedStarGsr
Honda Motorcycles
Jun 9, 2005 08:12 AM
1993acuraintgralsvtec
Apr 23, 2004 09:25 AM
SuperMan19
Dec 14, 2001 08:19 PM
