Car bogs when accelerating - JDM D15B
From a dead stop when I get on the accelerator the car really bogs badly and I am not sure why.
NO CODES!
I have new:
plugs
plug wires
fuel filter
newer cap and rotor (no carbon buildup)
TPS sensor
Does anyone know what may be causing this?
NO CODES!
I have new:
plugs
plug wires
fuel filter
TPS sensor
Did you reset the timing at the dizzy after your tune-up? That would probably be the biggest problem right there. Could also be that your TPS isn't zero'd too. I would start with those things.
Shiz, you could be right about the Dizzy being off... I moved it a little before I took it in to the shop...hopefully after I move it back it will resolve the problem.
Do you think it may be running too rich or lean with the problems I am having?
or is that not the case at all?
I doubt it. Sounds like it's all timing to me. Put a light on it and set it dead nuts. Make sure it feels right before advancing any farther.
EDIT: Make sure to reset the ecu after you reset the timing. Might not make a world of difference, but it could help a little.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NatedoggAZ »</TD></TR><TR><TD CLASS="quote">From a dead stop when I get on the accelerator the car really bogs badly and I am not sure why.
NO CODES!
I have new:
plugs
plug wires
fuel filter
TPS sensor
Does anyone know what may be causing this?</TD></TR></TABLE>
your problem is highlighted did you set your TPS after you installed it?
NO CODES!
I have new:
plugs
plug wires
fuel filter
TPS sensor
Actually I did not set the TPS - I figured that the shop would do that when they installed it yesterday.
How to I check it to be sure that it is set correctly?
using a voltmeter. You tap the middle wire going to the sensor with a safety pin or needle; this serves as an extension. Then you ground the black wire on your voltmeter to something on your engine ( i use the battery ground), and you read off of the pin using the red wire. At idle, (no throttle) it should read ~ .45 , at WOT (wide open throttle) it should read ~ 4.5. Hope this helps, i'm having the same problem with the bogging on acceleration, only i can't get my TPS to 4.5 at WOT. I think i just have a bad TPS sensor.
cool - thanks for the info!
unfortunately I dont have a voltage meter to check the TPS sensor, I should call the shop to see if they tested it after installing it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delScho »</TD></TR><TR><TD CLASS="quote">Did you reset the timing at the dizzy after your tune-up? </TD></TR></TABLE>
How do you do this? My dist is replaced, I didnt know I needed to set the timing again, never did that before.....
h-duced
Mar 12, 2009 01:45 PM
Proper
13
Oct 23, 2003 03:04 PM
240sx, accelerate, accelerating, accerlating, bad, badly, bogging, bogs, car, case, causing, d15b, jdm, optimus, sensor
