93 civic not starting up!!! HELP!
Old May 26, 2004 | 09:25 AM
niccuhles's Avatar
Default 93 civic not starting up!!! HELP!
I posted this in the tech section also...
I just bought a 93 civic DX coupe. The car wont start up when you turn it with the key, it will crank but wont start up. You can compression start the car and it was start up fine.
I checked all the fuses, switched out the cap, rotor, plugs, and plug wires. I had the starter checked and it works fine.
I was gonna change the coil in the distrubuter but the guy at the auto store told me that the car would not compression start without the coil.
The car was stolen before and the ignition was swtiched out, so i went in there with a multimeter and tested everything to make sure it plugged up right, and that was working fine, so what elses could it be?!?!?!?!
Old May 26, 2004 | 09:33 AM
Spade's Avatar
Default Re: 93 civic not starting up!!! HELP! (niccuhles)
Fuel?
Fuel filter, injectors, and fuel pump? Are they all in good running order?
Old May 26, 2004 | 09:58 AM
ctr136's Avatar
maybe something with the fuel. not to sound like an *** or anything but is the gas in it
Omar Heredia
29
Sep 30, 2012 12:09 PM
ravenracer
Sep 25, 2006 09:33 PM
DC4_MADMAN
33
Aug 8, 2005 05:00 AM
si00000
Nov 1, 2001 06:10 PM
