What Sway Bars do you guys recommend?
Old May 26, 2004 | 09:17 AM
hellrazr1208's Avatar
Default What Sway Bars do you guys recommend?
Hey, I'm tossed up with what sway bars I should run on my type-S. Should I just get a JDM rear sway bar, or the Progress front and rear kit, or the hotchkis street kit, or the neuspeed?
Old May 26, 2004 | 09:26 AM
Stea1th's Avatar
Default Re: What Sway Bars do you guys recommend? (hellrazr1208)
Hotchkies is awsome in my SRT..I'd say go with them, cause their products are
always ussualy good.
Old May 26, 2004 | 09:46 AM
MyCarGoesVroom's Avatar
Progress has some very well handling RSXs. You can't go wrong with Progress.
Old May 26, 2004 | 10:00 AM
AJ PwR's Avatar
DC-5 understeers to much and you just need a rear sway. I think JDM is a worthy upgrade for it's price but sure bigger is better for the DC5.
Old May 26, 2004 | 10:27 AM
DC5 03's Avatar
Default Re: What Sway Bars do you guys recommend? (AJ PwR)
I agree, any rear rotation you can get is a definite plus. Progess has very well developed parts and so does hotchkis. While it is probably milder than the aftermarket bars, the ITR rear sway is a great low cost solution to getting more rear end rotation.
Old May 26, 2004 | 10:57 AM
stealthhatch's Avatar
Default Re: What Sway Bars do you guys recommend? (DC5 03)
ive been thinking about getting the comptech rear tie/swaybar(non-ajustable) combo for my ep. wondering if anyone else has it and what they thought about it.
Old May 26, 2004 | 02:07 PM
sane 007's Avatar
Default Re: (MyCarGoesVroom)
progress
Old May 26, 2004 | 02:47 PM
civicvtec1ps's Avatar
Default Re: What Sway Bars do you guys recommend? (stealthhatch)
Get Progress.
Old May 26, 2004 | 03:01 PM
LOSERgirl's Avatar
Default Re: What Sway Bars do you guys recommend? (civicvtec1ps)
JDM DC5 rear sway
Old May 26, 2004 | 04:43 PM
RsxVengeance's Avatar
mugen 25mm rear swaybar.
Old May 26, 2004 | 06:31 PM
rsxmachine's Avatar
unless it's a track car, the 22mm JDM bar is all your RSX really needs. really balances the car well; one of the best mods you can get for under $100
Old May 26, 2004 | 07:09 PM
johnkimble's Avatar
progress 22mm PLUS a reinforcement plate
edit: if you haven't seen, robear and hondawerx both are selling them for around $140 shipped
Old May 26, 2004 | 10:25 PM
Jaypee's Avatar
Default Re: (johnkimble)
SRT-4? wha?
Old May 28, 2004 | 10:57 AM
NeVeR bLoWn's Avatar
Default Re: What Sway Bars do you guys recommend? (Stea1th)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stea1th &raquo;</TD></TR><TR><TD CLASS="quote">Hotchkies is awsome in my SRT..I'd say go with them, cause their products are
always ussualy good. </TD></TR></TABLE>
dan. this is a honda website...get out
next thing u know marc will be here 2...
Old May 30, 2004 | 04:28 AM
arctic-k20's Avatar
im happy with my hotchkis front and rear sway setup - but i have to say if i was doing it over from scratch i would probably go with a jdm rear bar and leave the front stock - best bang for the buck going!!
Old May 30, 2004 | 02:57 PM
CHILIBEANZ's Avatar
progress.
Old May 30, 2004 | 07:20 PM
budddavid's Avatar
I have heard that the type R rear helps out alot. I plan on getting one soon.
Old May 30, 2004 | 07:21 PM
03ephatch's Avatar
Default Re: (p220)
look down!
Old May 30, 2004 | 08:20 PM
Tenacious G's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthhatch &raquo;</TD></TR><TR><TD CLASS="quote">ive been thinking about getting the comptech rear tie/swaybar(non-ajustable) combo for my ep. wondering if anyone else has it and what they thought about it.</TD></TR></TABLE>
i'll be getting the comptech rear sway for my EP3, but w/o the tie bar. it's 22 mm, like the CTR rear sway and about the same price, so i'd figure i'd give it a shot since i'm a comptech *****.
but back on topic, progress's rear sway for the EP3 hits the exhaust, even the OEM exhaust piping. is this an issue w/ the DC5?
Old May 30, 2004 | 08:50 PM
ranivus's Avatar
Get the mugen sways or spoon sways
Old Jun 1, 2004 | 09:09 AM
CHILIBEANZ's Avatar
Default Re: What Sway Bars do you guys recommend? (Tenacious G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tenacious G &raquo;</TD></TR><TR><TD CLASS="quote">
but back on topic, progress's rear sway for the EP3 hits the exhaust, even the OEM exhaust piping. is this an issue w/ the DC5?</TD></TR></TABLE>
no ity's not an issue as long as everything is lined up correctly.
Old Jun 1, 2004 | 10:26 AM
Mr.TecH7's Avatar
What is the down side of going with 25mm fr and 25mm r on an ep3 just for street use?
Old Jun 1, 2004 | 10:36 AM
Default Re: (Mr.TecH7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.TecH7 &raquo;</TD></TR><TR><TD CLASS="quote">What is the down side of going with 25mm fr and 25mm r on an ep3 just for street use?</TD></TR></TABLE>
25 mm is pretty stiff for a rear sway on the EP3. from what i've read, 22 mm is stiff enough.
but to answer your question, a stiffer rear sway will reduce body roll and help your car rotate around easier (i.e. reduce understeer). the downside is your rear tires will break away easier if your tires aren't sticky enough. so if you're taking turns on the street too fast, you could lose control as your rear slides out.
Old Jun 1, 2004 | 12:36 PM
Type X's Avatar
i got progress front and rear sways from another member
and progress rear tie bar
hopefully this weekend they will be installed
and i will give you some input
till than they are just laying on my floor
Old Jun 1, 2004 | 01:43 PM
sane 007's Avatar
Default Re: (Tenacious G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tenacious G &raquo;</TD></TR><TR><TD CLASS="quote">25 mm is pretty stiff for a rear sway on the EP3. from what i've read, 22 mm is stiff enough.
but to answer your question, a stiffer rear sway will reduce body roll and help your car rotate around easier (i.e. reduce understeer). the downside is your rear tires will break away easier if your tires aren't sticky enough. so if you're taking turns on the street too fast, you could lose control as your rear slides out.</TD></TR></TABLE>
