Need pictures of a Dented gsr oil pan so i can compare with mine
Old May 26, 2004 | 06:30 AM
ramz7887's Avatar
Default Need pictures of a Dented gsr oil pan so i can compare with mine
I just got a dent in my oil pan. It looks kinda bad but i don't know if its too bad. I would like to see some pictures of denteted oil pans to campare with. The oil light doesn't go on so i guess its flowing well. The dent i think is from a drive way and its to the right of the exhaust header. Its about 3" long and maybe 1/2" deep.
Modified by ramz7887 at 3:46 PM 5/26/2004
Old May 26, 2004 | 06:43 AM
SuzukaBlueAP2's Avatar
Default Re: Need pictures of a Dented gsr oil pan so i can compare with mine (ramz7887)
Your oil light will only come one when the oil pressure drops below somewhere around 4 psi. By then, you're engine can be toasted.
Why don't you take a picture of your pan and let's decide if yours should be replaced or not?
Old May 26, 2004 | 06:45 AM
ramz7887's Avatar
Default Re: Need pictures of a Dented gsr oil pan so i can compare with mine (ScreaminTeg)
I don't have acces to a camera.
Old May 26, 2004 | 07:42 AM
ramz7887's Avatar
It doesn't look to bad now that i look closer. It just looks rasied a little bit under neith i've seen some other ones for sale that have similar dents.
Chumbas_EG9
Mar 31, 2007 04:20 PM
ramz7887
17
Mar 20, 2007 12:07 PM
hondaboy4life
Sep 29, 2006 08:01 AM
rival12
Sep 20, 2005 04:29 PM
FmXRider991
Apr 16, 2005 12:41 PM
