does hasport make diffrent motor mounts
Old May 25, 2004 | 11:19 PM
fuccarlos's Avatar
Default does hasport make diffrent motor mounts
here is he problem im having with my motor in a 91 crx motor-gsr head-b16 problem hood doesnt clear i already have the zc hood with the bump in it and it still hits any help would greatley apprecciated
Old May 25, 2004 | 11:55 PM
OnlyHJC's Avatar
wow that looks bad. good luck on your search
Old May 25, 2004 | 11:58 PM
importboi22's Avatar
Default Re: does hasport make diffrent motor mounts (fuccarlos)
where does it hit the hood at? take some of the underbracing off where it hits the hood
Old May 26, 2004 | 12:01 AM
UltimX's Avatar
get playdough and place it on the valve cover. Close the hood and find out where it hits. Cut the bracing and your set.
Old May 26, 2004 | 05:55 AM
deftones0817's Avatar
Default Re: (UltimX)
you need to get a sir hood not a zc hood. I dont know if there is a difference but there might be...
DEF
Old May 26, 2004 | 06:14 AM
crx_88_si's Avatar
the ZC hood is a Sir bump w/ USDM headlights, its ok. You need to cut bracing.
Did u use the b16 kit or b18 kit (the b18 kit lowers the engine slightly, for this exact reason)
Old May 26, 2004 | 07:19 AM
FULL-RACE EP3's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">
Did u use the b16 kit or b18 kit (the b18 kit lowers the engine slightly, for this exact reason)</TD></TR></TABLE>
Say what????
Go for the Place mounts, no probs clearing gsr motor...
Old May 26, 2004 | 07:26 AM
crx_88_si's Avatar
Default Re: (Pooptooth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pooptooth &raquo;</TD></TR><TR><TD CLASS="quote">
Say what????
Go for the Place mounts, no probs clearing gsr motor... </TD></TR></TABLE>
I believe hasport has two EF bseries kits, 1 kit for b16 and 1 kit for everything else. the 2nd kit (non b16 kit) lowers the engine slightly more then the b16 kit.
am I wrong?
N/M I have been misinformed.
Old May 26, 2004 | 07:30 AM
4drEF's Avatar
Keyboard Humorist
Have you asked Hasport about this?
Old May 26, 2004 | 07:32 AM
crx_88_si's Avatar
Default Re: does hasport make diffrent motor mounts (4drEF)
I just went to their site. It says you need to use a 90-93 teg left hand mount bracket to lower the engine slightly. ???
"Thank you for purchasing the Hasport EFB1 bolt in mount kit. This kit is designed to bolt in the 1st generation B16A, B17A and B18A engines into the 88-91 Civic or CRX. It can also be used to bolt in the B18C, B18B and B20B/Z engines with the addition of a different left-hand engine bracket (90-93 Acura Integra) Acura part no. 11910-PR3-010 and one of the 89-93 B-series cable transmissions."
Old May 26, 2004 | 09:26 AM
EL Vap133's Avatar
Default Re: does hasport make diffrent motor mounts (crx_88_si)
I believe they are making a new kit that allows you to have better hood clearance.
Old May 26, 2004 | 09:35 AM
hahagasdcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">get playdough and place it on the valve cover. Close the hood and find out where it hits. Cut the bracing and your set.</TD></TR></TABLE>
Try that and if that still doesn't work try to shim the motor down with some high grade washers between the block mount and the mount kit.
Old May 26, 2004 | 09:43 AM
buckNasty's Avatar
Default Re: (90crxzcgasd)
i have first generation hasport mounts, the old school welded ones and i had no problem with fitment and stock hood with a b18c at all.
something doesnt seem right on that height at all, my motor doesnt peek out like that.
Old May 26, 2004 | 09:48 AM
Bunger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">I just went to their site. It says you need to use a 90-93 teg left hand mount bracket to lower the engine slightly. ???
"Thank you for purchasing the Hasport EFB1 bolt in mount kit. This kit is designed to bolt in the 1st generation B16A, B17A and B18A engines into the 88-91 Civic or CRX. It can also be used to bolt in the B18C, B18B and B20B/Z engines with the addition of a different left-hand engine bracket (90-93 Acura Integra) Acura part no. 11910-PR3-010 and one of the 89-93 B-series cable transmissions."</TD></TR></TABLE>
You have to use the cable b-series drivers (USDM) engine mount with that kit, thats the difference. It doesn't have anything to do with lowering the engine. There is more than one EF-B mount kit, but its either for use with cable motors or hydro motors (new kit). Hasport has very carefully engineered their mount kits for proper ground clearance and axle angles. Thats why cheap mount kits aren't worth it, cause you end up going through axles once every 3 months. Besides, Hasport is great with their customers and they really know there stuff.
Old May 26, 2004 | 10:27 AM
paybac4223's Avatar
Default Re: does hasport make diffrent motor mounts (Bunger)
did you line up the rear mount to the proper hole?... on my ef i had to bash the cross member about 5 times so that the mount would make the rear of the engine sit about 1/2in-3/4in lower than it normally sat...i had no clearance issues....
Old May 26, 2004 | 01:04 PM
fuccarlos's Avatar
Default Re: does hasport make diffrent motor mounts (paybac4223)
the motor is completely bolted in i have the second gen hasport mounts (the cnc machined one) with my previous motor i didnt have these clearance problems which was b20 with the same head same mounts everything the same except the valve cover which was mugen and it rounder than the stock one which is more square so im just goona put my old valve cover on and hopefully that the problem
Old May 26, 2004 | 01:07 PM
fuccarlos's Avatar
yeah they told me im fu@#$# not in those words but thats what they meant
Old May 26, 2004 | 04:24 PM
red91g2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuccarlos &raquo;</TD></TR><TR><TD CLASS="quote">yeah they told me im fu@#$# not in those words but thats what they meant </TD></TR></TABLE>
So have u come up with a solution on wha your going to do now?
Old May 26, 2004 | 04:59 PM
0554's Avatar
i dont think hasport has came out with the b18 kit for 88-91 yet. i cant remember when brian said it was going to be out. but i am pretty sure its not out yet. only the b16 kit is out right now. i could be wrong though. but i just looked on their website and its not listed either
Old May 26, 2004 | 06:52 PM
buckNasty's Avatar
Default Re: (88crex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crex &raquo;</TD></TR><TR><TD CLASS="quote">i dont think hasport has came out with the b18 kit for 88-91 yet. i cant remember when brian said it was going to be out. but i am pretty sure its not out yet. only the b16 kit is out right now. i could be wrong though. but i just looked on their website and its not listed either</TD></TR></TABLE>
yeah its a b16 kit but i said i put in a b18c in mine with out a problem so i dunno
Old May 26, 2004 | 07:07 PM
0554's Avatar
Default Re: (bucbaby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bucbaby &raquo;</TD></TR><TR><TD CLASS="quote">
yeah its a b16 kit but i said i put in a b18c in mine with out a problem so i dunno</TD></TR></TABLE>
ohk i gotcha.
Old May 26, 2004 | 07:12 PM
0554's Avatar
i dont have a prob with my clearance either runnin my b18c but i also have a fiber images hood. which already has no webbing underneath
Old May 26, 2004 | 07:16 PM
T S R Performance's Avatar
If you have the cable to hydro conversion mount kit it will make your motor stick up like that. My bro has it and we had to beta the **** out of the hood in order to make it work
Old May 26, 2004 | 07:38 PM
xtrafastcivic's Avatar
Default Re: (T S R Performance)
i think the problem is your rear mount... did you dent down your rear crossmember? if that isnt the porblem i dont know what is.. and all you guys talking out of your *** just close it... b18 and b16 from the mounts up are the same... the b18 just hangs lower..... dealt...
Old May 26, 2004 | 10:21 PM
fuccarlos's Avatar
Default Re: (XtraFastCRX)
rear crossmemberis notched for clearance
