ecu questions.....
Old May 25, 2004 | 11:11 PM
n2oef's Avatar
Default ecu questions.....
ok i have a 90 dx with a dpi d16z6 swapped in-but i need to know what ecu i should use to convert to mpfi. should i go and convert to obd1 or stay odb0 with a vtec controller?which ecu can i use in either scenario?
Old May 26, 2004 | 03:37 AM
-16V-'s Avatar
Default Re: ecu questions..... (n2oef)
Well u can rig up a PM6 to fit, and get a VAFC...
Or get a P28 along with a conversion harness thing (OBD-0 To OBD-1), and a Z6 dizzy...
Old May 26, 2004 | 03:47 AM
crx_88_si's Avatar
Default Re: ecu questions..... (-16V-)
what dizzy are you using right now?
Old May 28, 2004 | 08:38 PM
n2oef's Avatar
Default Re: ecu questions..... (crx_88_si)
right now im usin the d15b2 dist rigged to work
Old May 29, 2004 | 01:57 AM
DJ_SaNdOz's Avatar
i would just do the obd1 conversion, much better in the long run.
MonkeyParty
May 6, 2014 02:04 PM
lildxr
Jun 19, 2005 05:17 PM
G2integra217
May 8, 2005 11:39 PM
