At WOT, car seems to hesitate above 4k rpm 92 Accord
Hey guys, just seeing if anyone can point me in the right direction and looking for a little help. My 92 Accord, seems to be in most gears other than 1st, it appears that when im driving pretty hard or at WOT, it seems to heitate a little instead of pulling cleanly up until redline, downshifts are fine, now i know its NOT my clutch cause its been replaced recently, it seems more of a fuel delivery issue. Any ideas guys, thanks alot.
p.s. im from torontoaccorsds.com
i just had similar problems, changed out my plug wires and it was fixed. i first started to miss under heavy acceleration@WOT, then gradually came on sooner. the heat ate my plug wires, the heat will eventually get to the wires. try that.
back to the basics, fuel, air, spark.
do you think it may be either fuel pump, fuel management or fuel filter. i hope not. thats more work involved, ill try what you mentioned. and i hope that fixes it
dman67
Jan 19, 2015 03:02 PM
JDMCRX
May 11, 2005 01:40 PM
