Injectors not working any ideas
Old May 25, 2004 | 10:21 PM
talagangpinoy's Avatar
Default Injectors not working any ideas
Hey guys wats up i jsut did a b18 swap on my crx first i tried running the car with the obd1 injectors by changing the clips but then the car would not start so i put back the obd0 clips in and ran it with the obd0 injectors then tried starting the car again but still didn't start, then i tested the injectors see if they were pulsing and putting fuel in the cylinder but they're not. Anyone know wat could be wrong with this? The car would not start at all cuz fuel is not going in. Please help
thanks
Old May 26, 2004 | 06:00 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: Injectors not working any ideas (talagangpinoy)
Main relay might not be working.
Did you go from DPFI to MPFI?
As always double check your wiring and grounds. Take a file and clean all the contacts for the grounds.
But I bet the main relay just pooped on you.
Old May 26, 2004 | 06:06 AM
Default Re: Injectors not working any ideas (The new Spaceballs)
No i didn't convert the car is an si with 4 injectors. Wat are the chances of the resistor box going bad? Also how can i tell if the ecu is working? Does the light just blink?
thanks,
Old May 26, 2004 | 06:55 AM
APEX CRX's Avatar
well if you are trying to run the OBD-1 injectors and have the resistor box plugged up I think thats your problem right there.
Old May 26, 2004 | 07:12 AM
4drEF's Avatar
Keyboard Humorist
When you put in the OBD-1 injectors did you remove the resistor box or not? With the OBD-1 injectors You are supposed to as well as chop off the resistor box connector and solder all the wires together.
With the OBD-0 injectors you leave the resistor box in there.
Your distributor may also be bad. The sensor in the distributor tells the ECU when to actuate the injectors.
Old May 26, 2004 | 10:35 AM
rioninja's Avatar
My guess would be its the tiny ground on the thermostat housing.
That definatly would cause the injectors not to pulse.
accordin 2 me
Dec 16, 2011 06:00 AM
LSV_REX
May 28, 2008 06:41 AM
e jay one
Aug 6, 2005 02:48 PM
HamiltonRex
19
Jul 10, 2004 01:05 PM
GOLDBERG
Mar 13, 2003 11:07 PM
