std clutch
no its not the same. it all deppends on the flywheel. if you have a 88-89 flywheel, you need the 88-89 pp/clutch. This is because the 90-91 flywheel has a different number of flywheel teeth than the 88-89. I did the same thing. tried to put a 91 clutch/pp on a 88 flywheel and didnt work. so get the same year clutch as your flywheel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitrousrush »</TD></TR><TR><TD CLASS="quote">Can i make my std 4 spd a 5 spd without swapping the tranny</TD></TR></TABLE>
Um no you need to swap your 4 speed transmission to a 5 speed transmission.
matt's hatch
Jan 30, 2010 06:03 PM
99sonicbluegsr
Mar 21, 2005 12:15 PM
