Porsche Brakes?
Old May 25, 2004 | 06:39 PM
ComptonAssDaniel's Avatar
Default Porsche Brakes?
Hey, so I did a little searching, although I see most people upgrade to the Legend/NSX brakes, and I'm wondering if anyones ever done Porsche Brakes, I know they're manufactured by Brembo...but I've also seen them on a few Integras. Has anyone else seen this done? Also does anyone know how this is done, or how to do it? Thanks...
Old May 25, 2004 | 07:34 PM
FlaN.'s Avatar
I don't think that will work
Old May 25, 2004 | 07:39 PM
95 integra's Avatar
Default Re: (FlaN.)
cooltech and some other brand did an upgrade using these back in the day. You have to have a bracket to use, much like the bracket thats in the AEM big brake upgrade....ofcourse thats only if you use bigger rotors.
Old May 25, 2004 | 07:45 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (95 integra)
Porsche brakes? If you mean take them out of a Porsche car and put them in our cars, they won't work that way. Sorry.
If you mean use the same manufacturer as what Porsche uses, then yes, you can.
Note that there are many brake options out there that are the same price and/or cheaper that will brake better than these so-called "Porsche Brakes."
Old May 25, 2004 | 08:58 PM
patmcd's Avatar
Default Re: (shamoo)
Im sure it could be done. But only by throwing a small brief case of money at it. You'd be way better off getting some sort of aftermarket setup.
Old May 25, 2004 | 10:05 PM
B18CYAAA's Avatar
Default Re: Porsche Brakes? (ComptonAssDaniel)
dont bother, you need to be putting out some serious power to need "porsche brakes" or another more affordable equivelant. If you had this power you wouldnt be asking this question.
On a lighter note, I saw "porsche brakes" on a new beetle the other day. He matched the calibers to valve cover and the valve cover to <U></U>his flower holder.
Old May 26, 2004 | 08:03 PM
I see...interesting. Just wondering. I wasn't saying that I had that kind of power(because if I did, I wouldn't be asking), but I've seen them on some cars...they say they're from AEM and just have the Porsche logos...I just didn't know how it was done. Thanks though.
Old May 26, 2004 | 08:07 PM
shamoo's Avatar
Default Re: (ComptonAssDaniel)
Those AEM ones are kits from AEM. They have large cross drilled/slotted rotors with the anodized center piece for bling.
Depending on how much money you want to spend (or how much bling you want), you can either stay with your stock calipers, which will give you a system with no braking improvement, a better looking brake system, and even possibly less braking performance. Or you can go with the AEM calipers, which I believe is a 4 or 6 caliper system which costs quite a bit more. That will definitely brake very well.
Old May 26, 2004 | 10:05 PM
riceball777's Avatar
just do the 11" brake up grade (itr, nsx, accord v6, legend, prelude)
it works good and it really wont cost that much
Old May 26, 2004 | 10:27 PM
jlv55's Avatar
Default Re: Porsche Brakes? (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">just do the 11" brake up grade (itr, nsx, accord v6, legend, prelude)
it works good and it really wont cost that much</TD></TR></TABLE>
preludes have bigger brake rotors than 4cyl accords?
Ludster
Dec 15, 2010 12:18 PM
supaslowdx
Suspension & Brakes
Mar 3, 2010 07:07 AM
xtremvw
Jan 22, 2010 07:42 AM
efficiencyJunkie
Honda Civic (2001 - 2005)
Feb 8, 2008 10:13 PM
PearlWhiteDC5
Mar 3, 2006 02:07 AM
