1988 Accord LX AC nit turning on
Where is the fuse to my AC compressor clutch? It does not engage when turned on and I suspect a fuse? Can anyone shed some light on this please?
thanks,
js hoopes
thanks,
js hoopes
well.. the fuse box is on the drivers side of the car below the dash board. if you look around you will find all the main fuses. if you are havin problems with the AC the check that the belt that drives the compressor works well. the compressor is mounted on the front of the engine. right in between the radiator and the engine. also check that the whole thing actually has the freyon stuff in there. if its not discharged. Also there is another box of fuses on the left side of the motor in a black l shaped box. it is above the air intake and when you open it you can check everything there aswell.
this sounds like n00b advice. but thats all i could think of. hopefully some of it helps even a small bit.
pro1911
Jun 29, 2024 09:52 AM
Hanmin
Aug 6, 2008 09:59 AM
redsub9802
Nov 1, 2006 02:54 PM
dc2jdmteg05
Jul 20, 2005 12:37 PM
