washers+hood hinges=much cooler inside my car...
Old May 25, 2004 | 05:53 PM
mildly.interesting's Avatar
Default washers+hood hinges=much cooler inside my car...
I'd just like to say that the washer trick on your hood hinges is the bestest free heat removal system ever. My floorboards used to cook like a Nascar car, but now it all flows harmlessly out of the cowl panel.
I know I'm not the only one to do this, but I just so surprised that something that easy could work so well.
After I wrap my manifold and DP, my car will be cool as the proverbial cucumber
Old May 25, 2004 | 06:58 PM
Casey's Avatar
Default Re: washers+hood hinges=much cooler inside my car... (mildly interesting)
are you referring to the jdm y0! drifter trick that all the nissan guys are doing? ive heard it works but God help me if someone says Im trying to be JDM or a drifter Its going to take all i have to hold back from putting my foot in their ***
Old May 25, 2004 | 07:07 PM
LOL, I'm gonna be proud to say I was the first dude on this end of NC to do it. It really works well though, kinda the same principle as a cowl induction hood on an old Chevelle...
Old May 25, 2004 | 07:15 PM
kwiker's Avatar
Default Re: (mildly interesting)
what exactly is this trick??? thanks
Old May 25, 2004 | 07:45 PM
just a few washers between your hood hinges and your hood lets it sit higher in the back, thus venting heat at the cowl...
Old May 25, 2004 | 08:00 PM
Dr Pooface's Avatar
Default Re: washers+hood hinges=much cooler inside my car... (Casey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">are you referring to the jdm y0! drifter trick that all the nissan guys are doing? </TD></TR></TABLE>
Lol, domestic owners have been doing that since forever.
Old May 26, 2004 | 04:00 AM
Smooth-GSR's Avatar
Default Re: washers+hood hinges=much cooler inside my car... (Dr Pooface)
Sounds like a good idea, although appereance wise it may not be the best.... but hey, who's in it for appereances...
Old May 26, 2004 | 04:12 AM
Casey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">
Lol, domestic owners have been doing that since forever.</TD></TR></TABLE>
i know, but every dumbass, i mean "drifter" around here does it which is why i said that
Old May 26, 2004 | 05:23 AM
the way my feet felt on the way back from Rockingham, I'm lucky I still have a hood on it...when you need asbestos shoes to drive your car, appearance isn't an issue
Old May 26, 2004 | 05:37 AM
PM-Performance's Avatar
how many and what size washers did you use?
Old May 26, 2004 | 06:22 AM
6MM bolts and washers, like 6 on the front bolt and 7 on the rear...
Old May 26, 2004 | 06:34 AM
RobbieG35's Avatar
12 Years Strong
Any pics of it?
Old May 26, 2004 | 06:41 AM
tthame1's Avatar
Default Re: (HybridHatch88)
anybody done this w/ a carbon fiber hood? Will it cause the hinges to rip out of the hood at high mph due to the extra lift?
Old May 26, 2004 | 06:45 AM
kyle h.'s Avatar
Default Re: (tthame1)
i would think, this might be a good thing for carbon hoods. maybe provide a little bit more downforce, since its like a ramp now. but maybe im just all mied up.
Old May 26, 2004 | 06:52 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthame1 &raquo;</TD></TR><TR><TD CLASS="quote">anybody done this w/ a carbon fiber hood? Will it cause the hinges to rip out of the hood at high mph due to the extra lift?</TD></TR></TABLE>
There is no extra "lift" created by this modification. The air does not go OUT of the engine bay , it actually goes "IN". The pressure differential will always flow to the area with the least pressure, mainly under the hood. The cooling effect you're experiencing doesn't come from the fact that air is "escaping" out the rear, but actually air flowing "into" the engine bay and escaping underneath.
So in essence, you'll gain an extra point of downforce by the increased rake.
Old May 26, 2004 | 06:54 AM
tthame1's Avatar
Default Re: (Finest)
So will the added downforce be enough to affect 1/4 mile traps?
Old May 26, 2004 | 07:05 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthame1 &raquo;</TD></TR><TR><TD CLASS="quote">So will the added downforce be enough to affect 1/4 mile traps?</TD></TR></TABLE>
Uh...probably not.
1) 1/4 mile trap speeds are usually an indication of HP and acceleration.
2) Your typical Civic probably isn't going quick enough to need the additional downforce for added traction purposes.
3) Your typical Civic probably doesn't have a top heavy powerband that requires additional traction during the second half of the 1320.
It looks cool, and keeps your engine bay cool. The end.
Old May 26, 2004 | 07:06 AM
wade's Avatar
wow i didnt know it worked that well, take pics because i was thinking more like 2-3 washers, not 6 to 7. PICS
Old May 26, 2004 | 07:48 AM
Default Re: (wade)
yea i have a CF hood, im just worried about the hinged ripping out or something .
Old May 26, 2004 | 07:56 AM
94CivSi's Avatar
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">yea i have a CF hood, im just worried about the hinged ripping out or something .</TD></TR></TABLE>
Get longer hood bolts, problem solved. Keep in mind, your only moving the hood maybe 1/2" in the rear, the wind won't make that much of a difference.
Old May 26, 2004 | 08:22 AM
jonnybravo's Avatar
I have a CF hood and I did this mod. Works really well. Make sure you use large washers. About 1" round should do it and longer bolts. The larger washers provider better weight and stress distribution to reduce cracking and breaking.
Old May 26, 2004 | 09:39 AM
Kwuaymaikrup's Avatar
Default Re: (jonnybravo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonnybravo &raquo;</TD></TR><TR><TD CLASS="quote">I have a CF hood and I did this mod. Works really well. Make sure you use large washers. About 1" round should do it and longer bolts. The larger washers provider better weight and stress distribution to reduce cracking and breaking. </TD></TR></TABLE>
I actually put the washers in between the hinge and the car. That way there is no worries of altering the hood mounting locations.
-Ryan
Old May 26, 2004 | 09:41 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (Kwuaymaikrup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">
-Ryan</TD></TR></TABLE>
Smart, I will do mine this way.
Old May 26, 2004 | 10:04 AM
Default Re: (DaX)
interesting . ithink i like that idea better. . . will that affect snapping in my hood pins by raising the back up?
Old May 26, 2004 | 10:11 AM
funky_cornbread's Avatar
pics?
