Tire pressure for rear skinnies?
Old May 25, 2004 | 04:17 PM
whatVTEC's Avatar
Default Tire pressure for rear skinnies?
how much psi are you guys running in the rear skinnies?
Old May 25, 2004 | 04:21 PM
Zero4Racing's Avatar
Default Re: Tire pressure for rear skinnies? (whatVTEC)
as much as possible on your skinnies, depending on the maker. you want those things as full as possible to help limit the amount of dip the rear end takes coming out of the hole. i think we're at around 40-45 psi.....
Old May 25, 2004 | 05:17 PM
lugnuts's Avatar
Default Re: Tire pressure for rear skinnies? (Zero4Racing)
45 psi on the track and 35 psi for towing , hehe
Old May 25, 2004 | 06:11 PM
A.RODD's Avatar
Default Re: Tire pressure for rear skinnies? (lugnuts)
i run 30psi on kenny's car.....
Old May 25, 2004 | 06:25 PM
DEVIOUS_EG*'s Avatar
50 psi...
Old May 25, 2004 | 10:09 PM
SlicksMH's Avatar
Default Re: Tire pressure for rear skinnies? (DEVIOUS_EF*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEVIOUS_EF* &raquo;</TD></TR><TR><TD CLASS="quote">50 psi... </TD></TR></TABLE>
That would be the max.
John@M&H-=Hashims
Old May 26, 2004 | 11:57 AM
whatVTEC's Avatar
Default Re: Tire pressure for rear skinnies? (SlicksMH)
Thanks for the replies guys, I think last time I ran them around 30psi.
Just wanted to check to see if it was around the right amount.
xtrafastcivic
Apr 17, 2006 02:35 AM
pchan
Honda Motorcycles
10
Jul 24, 2005 07:46 PM
2000GSR
Honda Motorcycles
11
Mar 30, 2005 07:58 PM
raene
14
Feb 12, 2003 05:05 PM
Sam
Nov 15, 2001 02:33 PM
