moved to CO idle seems to have problems?
Old May 25, 2004 | 03:28 PM
91LSVTEC HB's Avatar
Default moved to CO idle seems to have problems?
wat up i just moved to colorado and the city is about 6000 ft up and my idle seems to have major problems! i cant seem to get it to idle at normal! it wants to idle at 100-200 and slowly die. ive tried to mess w/ the idle sensor but nothing really worked to well?? anything w/ help please thanks
Old May 25, 2004 | 04:14 PM
hatchback_al's Avatar
Default Re: moved to CO idle seems to have problems? (91LSVTEC HB)
i would liek to know also, im moving to CO soon and i figured i would have some car problems
Old May 25, 2004 | 04:58 PM
Default Re: moved to CO idle seems to have problems? (hatchback_al)
ne one??
Old May 25, 2004 | 05:49 PM
sm00thk0zz's Avatar
Ya just need to turbo, purly for running purposes in high altitudes
Old May 25, 2004 | 05:51 PM
Default Re: moved to CO idle seems to have problems? (sm00thk0zz)
haha thats true! but id be running over 300 whp but thats fine too!
Old May 25, 2004 | 06:54 PM
good! i was worried my turbo would make it worse in the high altitude! good news for me
Old May 25, 2004 | 06:56 PM
mr. carpenter's Avatar
did you try the idle adjust screw? new air filter?
Old May 25, 2004 | 07:14 PM
Default Re: moved to CO idle seems to have problems? (mr. carpenter)
yep tried the screw and the filter is brand new
Old May 25, 2004 | 07:54 PM
possibly maybe it could be your head gasket or head cover gasket. is it alot colder? where did you move from? it could be a fuel system related problem. is your tach jumpy?
Old May 25, 2004 | 07:56 PM
i moved from so cal and my gaskets are all good!
Old May 25, 2004 | 07:57 PM
tach is fine, around 75-80 most of the time(temp)
Old May 25, 2004 | 07:59 PM
fuel or timing? codes?
Old May 25, 2004 | 08:03 PM
FUEL GOOD, i noticed my belt maybe a tiny bit loose, not much tho, its still lining up dead on..., no codes either
Old May 25, 2004 | 08:10 PM
good spark? i would just redo all the cheapest items that have'nt been done recently and hope for the best, that it's not something internal. what motor is it
Old May 26, 2004 | 06:11 AM
good spark, changed those recently, ls/vtec b18b1 1700 miles on it brand new motor
Old May 26, 2004 | 06:17 AM
crx_88_si's Avatar
- Warm up the car completely (fan comes on)
- disconnect IACV
- adjust idle screw to get idle to 600rpm
- turn car off
- plug the iacv back in
- RESET ECU (important)
- start car and let it idle til fully warm again, then turn on high beams and defroster for 2 min.
Old May 26, 2004 | 06:31 AM
Default Re: (crx_88_si)
im retarded!! wat is the iacv??
Old May 26, 2004 | 06:42 AM
crx_88_si's Avatar
Default Re: (91LSVTEC HB)
Idle Air Control Valve, right at the back of the pass side of the IM, can't miss it.
Old May 26, 2004 | 06:44 AM
its not that little black rubber cap is it?
Old May 26, 2004 | 07:13 AM
crx_88_si's Avatar
Red Circle = IACV
Old May 26, 2004 | 07:18 AM
oh ok i have a type R IM
Old May 26, 2004 | 07:37 AM
crx_88_si's Avatar
oh ok.. should be same location though.
Old May 26, 2004 | 08:15 AM
ok just disconnect when the car is idling and then shut off and plug back in??
Old May 26, 2004 | 08:22 AM
crx_88_si's Avatar
no, you gotta set base idle w/ the screw (600rpm). shut the car off, then plug it back in, reset the ecu (pull hazard fuse for 20 sec), then turn the car back on.
Old May 26, 2004 | 08:25 AM
i tried messin w/ the screw but got nothin, loosend it and it would die, tighten it and it didnt change from before! will still die every now and then
