EG DIY BLACK HOUSING
Old May 25, 2004 | 02:35 PM
nichols_si's Avatar
Default EG DIY BLACK HOUSING
ive searched an searched an searched... only found 1 article upon very minimal info on the EG DIY.. alot on ek em1's etc. I need a few tips, i got the basic's such as:
- backing procedure ( 220degrees for 5-10 minutes )
- prying apart steps
- re assembling
need tips on:
- should i sand the housing down? or just run few primer coats on it?
- no need to remove bumper for eg to remove headlights correct?
anything else?? thans HT yet again
Old May 25, 2004 | 02:39 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: EG DIY BLACK HOUSING (nichols_si)
It should be the same prcoess as any other DIY black housing headlight process.. No, you dont have to remove the bumper to get the headlights out, and no, you dont have to sand anything down, but it always helps with making the paint stick. Good luck.
Old May 25, 2004 | 02:41 PM
nichols_si's Avatar
thanks . ill end up posting pics when this is complete. now its just clear lights w/ clear visions, im gona amber the visions + black housing, on my black eg should look tight
EG-tofu
Sep 6, 2006 07:35 PM
Slow Ek
Aug 1, 2006 01:16 PM
KOALA YUMMIES
32
May 31, 2003 08:10 PM
PotatoePAPA
May 27, 2003 03:48 PM
juicedricer
16
Jan 18, 2003 07:16 PM
