Parking brake light stays on... wtf. Anyone have this problem?
Old May 25, 2004 | 01:53 PM
JSPECHB's Avatar
Default Parking brake light stays on... wtf. Anyone have this problem?
When I put my parking brake (e-brake) handle down the light stays on. Has this happen to anyone and is there a way to fix it?
I unplugged the clip... still on.
Disconnected the battery... still on.
Reset my ecu...still on.
Old May 25, 2004 | 01:57 PM
LilGreenMachine's Avatar
Default Re: Parking brake light stays on... wtf. Anyone have this problem? (JSPECHB)
How long ago did it happen? Are you losing brake pressure? If so check the lines. Try bleeding your brakes. If that stuff doesn't work, your M/C might be going bad.
Old May 25, 2004 | 02:14 PM
JSPECHB's Avatar
Default Re: Parking brake light stays on... wtf. Anyone have this problem? (LilGreenMachine)
Maybe I just need new brakes all around?
Old May 25, 2004 | 02:35 PM
Jurassic Four's Avatar
From: Where you cant steal it, Maryland, United States
That isnt just your parking brake light... that is your brake warning light also. You might be really low on fluid, or your master cylinder could be blown (that happened to me)
Old May 25, 2004 | 02:48 PM
JSPECHB's Avatar
Default Re: Parking brake light stays on... wtf. Anyone have this problem? (Jurassic Four)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jurassic Four &raquo;</TD></TR><TR><TD CLASS="quote">That isnt just your parking brake light... that is your brake warning light also. You might be really low on fluid</TD></TR></TABLE>
Low on fluid is what it was. thanks
Old May 25, 2004 | 04:25 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECHB &raquo;</TD></TR><TR><TD CLASS="quote">
Low on fluid is what it was. thanks</TD></TR></TABLE>
The infamous low on fluid trick.
Thatssojdm
Feb 26, 2008 08:05 AM
Gsrteggrl
Jul 2, 2005 10:06 AM
civicboisi
Mar 8, 2003 06:45 AM
94BlackRS
Nov 28, 2002 02:43 PM
hybridbmw
Feb 19, 2002 10:38 AM
