Clutch creak at the bottom
Old May 25, 2004 | 12:47 PM
JiggyKooAndy's Avatar
Default Clutch creak at the bottom
When I depress the clutch pedal, it creaks towards the bottom of depressing (near the floor). I just replaced my clutch with an exedy, and the clutch itself is engaging and whatnot fine. I will bleed the fluid this weekend, any other suggestions/possibilities of what it could be? It's not really a big problem...kind of just a nuisance (sp?).
Old May 25, 2004 | 01:12 PM
RGoose18's Avatar
Default Re: Clutch creak at the bottom (JiggyKooAndy)
I've got the same problem, real annoying
Old May 25, 2004 | 01:17 PM
Mugen Mike's Avatar
Is it possible the hinge just needs to be lubricated?
Old May 25, 2004 | 01:18 PM
Kicker773's Avatar
Default Re: Clutch creak at the bottom (RGoose18)
i've heard greasin the spring up of the clutch master cylinder helps.. dunno i actually replaced mine but now it startin to make that noise again.. let me know what your gonna do..i'm chicago.. be willin to meet up and do a DIY day
Old May 25, 2004 | 05:41 PM
hatchdrvr's Avatar
It must be a Honda thing, because mine does that too.
Old May 25, 2004 | 05:44 PM
Default Re: Clutch creak at the bottom (Kicker773)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kicker773 &raquo;</TD></TR><TR><TD CLASS="quote">
...i'm chicago.. be willin to meet up and do a DIY day </TD></TR></TABLE>
next meet we'll fiddle around with it :-P
Old May 25, 2004 | 09:05 PM
TypeR15's Avatar
mine does it 2
Old May 25, 2004 | 09:33 PM
RGoose18's Avatar
Default Re: Clutch creak at the bottom (TypeR15)
How much play do you guys have at the top of your clutch??? Mine seems to have an awful lot before the clutch begins to engage
Old May 26, 2004 | 12:20 AM
DB8ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR15 &raquo;</TD></TR><TR><TD CLASS="quote">mine does it 2 </TD></TR></TABLE>
Ditto. If anyone knows the solution to this problem please post
Old May 26, 2004 | 02:35 AM
magic hat #9's Avatar
Default Re: Clutch creak at the bottom (R #189)
when my clutch pedal creaked, it was a worn throwout bearing and the clutch engagement arm needed to be lubed.
Old May 26, 2004 | 03:23 AM
Default Re: Clutch creak at the bottom (magic hat #9)
hmmmm...i hope that's not my problem. I just replaced the throwout bearing when i threw the new clutch in there...
Old May 26, 2004 | 03:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGoose18 &raquo;</TD></TR><TR><TD CLASS="quote">How much play do you guys have at the top of your clutch??? Mine seems to have an awful lot before the clutch begins to engage </TD></TR></TABLE>
yep, i've got a good amount...i guess i'm just used to it so it seems 'normal' to me. But now that i think about it, i do remember thinking it was quite a ways up when i was first getting used to it when i bought the car. It has been pretty far up with the stock clutch...and the exedy, so i don't think it's something to really worry about.
JFG Kevin
Sep 12, 2006 04:48 PM
Felt.2
Aug 13, 2006 03:47 PM
iLOVEmyEMone
Oct 28, 2005 05:31 PM
jazz1320
Aug 2, 2005 01:27 PM
ibe2fly
Jul 10, 2004 03:31 PM
