Quick ? about a 95 intake manifold with injectors
You can still use them with either OBD0 or OBD1 ECUs though. For OBD1 you don't use the injector box. Do run them the same way with the OBD0 ECU - hack off the resistor box plug on your harness and solder the wires together.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">You can still use them with either OBD0 or OBD1 ECUs though. For OBD1 you don't use the injector box. Do run them the same way with the OBD0 ECU - hack off the resistor box plug on your harness and solder the wires together.</TD></TR></TABLE>
This is exactly what I did, it's a lot cleaner than with the resistor box
surkitroller
Dec 29, 2009 12:58 PM
rogue3221
Nov 23, 2004 11:36 AM
mr. Grind
Aug 13, 2004 04:08 PM
