What all is needed to fix wheel bearings?
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Wheel bearings on the front have just worn and worn away, so I might as well change them since I still own the car. They are making mad noise when the wheel input turns one way or the other. What all is needed as far as parts & l00b are concerned? Easy fix?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo »</TD></TR><TR><TD CLASS="quote">and the ability to use the search function...
w1ll0rd made big **** sweet post aboot this....
</TD></TR></TABLE>w1ll0rd made big **** sweet post aboot this....
fugg me. where's the
icon when you need it.
Do you need a new wheel stud as well as honda wheel bearing or can you reuse the old studs? (will had ARP studs)
You can use the old hub/studs. I replaced the hub assembly at the same time as the wheel bearing when I did mine a few weeks ago. Makes the job easier, but isn't neccessary
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hungsteR »</TD></TR><TR><TD CLASS="quote">Any other symptoms associated with this? Do you get any steering wheel vibration?</TD></TR></TABLE>
nope, steering is fine, it just makes a funny noise when you turn it one way or the other.
