Just got my B18C1 Delivered today!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I was wondering if anyone knew where i could find maybe instructions on doing the gsr swap into a 96 civic ex.... please respond asap or msg me..
Aim - CLVLC2NV
EMAIL - chris.kouse@twcable.com , chriskouse@woh.rr.com
Aim - CLVLC2NV
I hate to be the first to sayit but there are so many threads on this.....try to do a search before you post.
The swap itself is usually pretty straight forward. You will need a mount kit. A helms manual would help too.
You will also need a cherry picker/ engine left as well and a few buddies wouldn't hurt.
edit:
there is ALSO an <u>ARCHIVE</u> thread that is at the top of this forum. A lot of very good info is in that thread.
edit:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Teal »</TD></TR><TR><TD CLASS="quote">I hate to be the first to sayit but there are so many threads on this.....try to do a search before you post.
edit:
You don't need a cherry picker, nor you need the whole mount kit. You can peace one together from other cars, like integra, del sol.
edit:
</TD></TR></TABLE>You don't need a cherry picker, nor you need the whole mount kit. You can peace one together from other cars, like integra, del sol.
edit:
you don't NEED a mount kit
edit:
</TD></TR></TABLE>you don't NEED a mount kit
here ya go.. you lazy ***... SEARCH!!!
b-series install
https://honda-tech.com/zerothread?id=131949
wiring info
https://honda-tech.com/zerothread?id=558245
HOW TO REMOVE THE ENGINE WITHOUT A HOIST
https://honda-tech.com/zerothread?id=466327
if you need more info your on your own
b-series install
wiring info
Ok...it sorta looks like 1 of the motor mounts isnt going to match up...which would is it exactly.... and what do i need to replace it with ..... 99 si motor mount?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacivic2nv »</TD></TR><TR><TD CLASS="quote">99 si motor mount?
ok it looks like im going to need the motor mount at the transmission end and the motor mount at the timing chain end....is there some sorta of a converting motor mount im going to need when going from the d series motor to the b series... i did have in the car a 1.6 SOHC VTEC...and it was a 96 HONDA CIVIC EX COUPE...if the stock motor mounts off my old motor would work i still have a problem...i think i threw them away......so i need to know what exactly i need...
Pretty much the easiest thing i need to know is what motor mounts will work in my car...like i said
i have a 96 civic ex coupe 1.6 sohc vtec... so what motor mounts will bolt to my car and the gsr b18c1 motor
Modified by hondacivic2nv at 4:38 AM 5/26/2004
stehigs321
Feb 16, 2004 03:18 PM
compwc18
Jan 29, 2004 07:38 PM
