93 integra Ls axels/ 91 civic dx hubs Not going in, not even close. PLEASE HELP!
Old May 25, 2004 | 06:42 AM
Dainbramage's Avatar
Default 93 integra Ls axels/ 91 civic dx hubs Not going in, not even close. PLEASE HELP!
ok ive got 93 integra ls axels and the halfshaft. The halfshaft is in my b16a1 and fit perfectly. The axels fit my halfshaft. But I got 91 civic dx hubs and knuckles like everyone has told me to and the integra axels are too thick. They dont even slide down that inch to be able to line the splines up. Can anyone help at all!?! btw its a 91 crx hf
Old May 25, 2004 | 12:25 PM
civickiller's Avatar
Default Re: 93 integra Ls axels/ 91 civic dx hubs Not going in, not even close. PLEASE HELP! (self2884)
idk what your asking but did you make sure they are 5 speed hubs ? try and put the axle in from the outside, it should fit in. make sure you remove the dust shield on the inside of the hub
i dont understand what you mean when you say you cant even get it slide down an inch to line up the splines, i dont get that
Old May 25, 2004 | 12:37 PM
doublejz's Avatar
Default Re: 93 integra Ls axels/ 91 civic dx hubs Not going in, not even close. PLEASE HELP! (civickiller)
im using auto hubs, they are the same, why not just get 90-93 teg hubs, then you know they'll fit
Old May 25, 2004 | 01:33 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: 93 integra Ls axels/ 91 civic dx hubs Not going in, not even close. PLEASE HELP! (doublejz)
the 89-91 5 speed hubs will werk
Old May 25, 2004 | 06:31 PM
nobody has ever told me about a dust shield. You think that would cause it not to fit? Ill try it
Old May 26, 2004 | 09:30 AM
DYNO-PRO
it would not cause the splines to not slip in however it would cause the axel to stop short of butting up to the hub
Old May 26, 2004 | 04:52 PM
Default Re: 93 integra Ls axels/ 91 civic dx hubs Not going in, not even close. PLEASE HELP! (HOOKUPS)
that didnt work. Ok, if the half shaft fit into the motor, and the axel fit the half shaft, and the axel is too big for the hub, then it must be the wrong hub. Correct?
Old May 26, 2004 | 05:35 PM
DYNO-PRO
YES WRONG HUB
im_a_EF-er
Dec 10, 2008 09:40 AM
jdmDRIFTER
Mar 8, 2007 11:59 PM
burge
May 7, 2006 01:47 PM
Dainbramage
Jun 23, 2004 03:37 PM
91GSteggy
Apr 21, 2004 01:48 PM
