How Much Boost Is OK!?!
Whats Up Fellas well i just got a boost controller and i was curious what everyones opinion on how much boost i could push without risking detonation. I have a 2000 Civic Si (B16A2) with JE 9.0:1 pistons and stock rods. My fuel system is ok to handle high boost except for my virgin ECU (thatll be fixed soon
) So what do yall think...i was thinkin like 14 PSI but id like an experienced opinion.
Thanks ....Y2KCivicSiR
) So what do yall think...i was thinkin like 14 PSI but id like an experienced opinion.Thanks ....Y2KCivicSiR
While on a dyno at a professional shop, tuning my motor with Eagle rods, Endyne pistons, an STR blockguard, and a good tunable ECU with good sized injectors and fuel pump, we deemed it a safe streetcar limit at 1 bar, which is about 14.5 PSI.
I completely agree with this assumption. 1 tank of even slightly bad gas with just slightly off tuning can spell disaster for stock sleeves when you're pushing 2x the normal cylinder pressures on our engines.
If I had delegated to step up to some race gas, they were all for upping the horsepower ante, but I'm all about my streetcar-ness with my car. I'll make the number on pump gas, thank you.
My fuel system consists of walboro fuel pump AEM fuelrail/regulator and RC 310cc injectors...right now im running my timing at 2degrees adv. on intake and 1degree ret. on exhaust. I have a stock ECU tho...thats gonna hold me back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2KCivicSiR »</TD></TR><TR><TD CLASS="quote">My fuel system consists of walboro fuel pump AEM fuelrail/regulator and RC 310cc injectors...right now im running my timing at 2degrees adv. on intake and 1degree ret. on exhaust. I have a stock ECU tho...thats gonna hold me back.
Without any GOOD way of tuning the car, and if you don't have a wideband handy, 7-8 psi is pushing your luck... Get it on a dyno and tune it before upping the boost.
</TD></TR></TABLE>Without any GOOD way of tuning the car, and if you don't have a wideband handy, 7-8 psi is pushing your luck... Get it on a dyno and tune it before upping the boost.
Umm...you do know that's cam timing and not ignition timing right? You need to alter ignition timing.
</TD></TR></TABLE>Umm...you do know that's cam timing and not ignition timing right? You need to alter ignition timing.
I would not even think of turning up the boost that far on 310s.
Find you some 550s and get SOME sort of engine mgmt before you are rebuilding that thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2KCivicSiR »</TD></TR><TR><TD CLASS="quote">Well guys...what can i say...im an idiot...i blew my head gasket on the #2 cylinder....CRAP!! im so stupid
...did you even read the answers to your post??
At least its a head gasket and not a cracked sleeve
</TD></TR></TABLE>At least its a head gasket and not a cracked sleeve
Now that you bring that up it could be a cracked sleeve....i wont find out untill i pull the head off on friday
im scared....
im scared....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VNTEC »</TD></TR><TR><TD CLASS="quote">How much did u run anyways?</TD></TR></TABLE> 16.5PSI...LOL before you tell me...yes i already know...im an IDIOT!
Bro...you know you're an idiot, right?
Seriously though, I give you a round of applause for trying it. For all we know, we could have been duped all this time and 16.5 was actually safe. You would have pioneered that. Think Jinxproof and stock blocks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2KCivicSiR »</TD></TR><TR><TD CLASS="quote">Whats Up Fellas well i just got a boost controller and i was curious what everyones opinion on how much boost i could push without risking detonation. I have a 2000 Civic Si (B16A2) with JE 9.0:1 pistons and stock rods. My fuel system is ok to handle high boost except for my virgin ECU (thatll be fixed soon
</TD></TR></TABLE> Hey how much power do you make at the wheel HP and TQ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warhorse 4.6 »</TD></TR><TR><TD CLASS="quote"> Hey how much power do you make at the wheel HP and TQ
</TD></TR></TABLE>I havent the slightest clue what the exact #s are because i have never dynoed the car
i run a stock block d16y7/d16z6 mini-me with comp 59300 cam and 14B @10psi all day long on 92 octane.
450cc DSM injectors and a turboEDIT tuned PM6 on a basemap that i made from PM7 maps.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2KCivicSiR »</TD></TR><TR><TD CLASS="quote">Well the verdict is in....i blew my sleeve on the #2...im totally fu*ked....wonderful
rebuild it and give it to someone who deserves it
I run 1 Bar (14.7) on a stock B16a (2mm headgasket) and plan to boost more now that i have larger injectors
</TD></TR></TABLE>rebuild it and give it to someone who deserves it
wow ... i dont even know how to respond to what u did.. first mistake it sounds like u didnt do your homework on turbo Dos and Donts. what possessed u to boost on 310cc injectors WITHOUT ANY engine management or even FMU for for that matter i have no clue. all well.. lesson learned.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">21 psi on stock rods & pistons?
wtf
i dont belive it.</TD></TR></TABLE>
holy ****...21psi, that must scare the internals
21 psi means nothing. He said hes running 450cc injectors so i doubt hes make much over 325whp, which is what really matters. Stock motors have held alot more.
wtf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2KCivicSiR »</TD></TR><TR><TD CLASS="quote"> 16.5PSI...LOL before you tell me...yes i already know...im an IDIOT!
Great job.
Do you know that after you hit 11 psi, the ECU can't add fuel anymore anyway (considering the fact that you have 310 cc/min injectors, it probably started leaning out around 5 psi.)
I bet you were leaner than stoich in boost.
Good job though. I mean, if you don't know what's going on, it's always a good idea to change stuff.
</TD></TR></TABLE>Great job.
