my b18b eg wont stay on without revvin it
Old May 25, 2004 | 12:07 AM
wsiracerz's Avatar
Default my b18b eg wont stay on without revvin it
so i finished my swap(or so i thought), its an obd2 b18b an i converted it to obd1 with wire harness an injectors an dizzy an ecu, prob is when i start it i have to give it gas an keep gassin it for it to stay on, on obd2 ls's theres a sensor on top of intake manifold, i have not wired it up yet cuz i jus got the plug to plug into manifold tonite, could this be the prob? jus wonderin on opinions, i will have results tomorow mornin when i wire it up
Old May 25, 2004 | 06:33 AM
kur0ryu's Avatar
Default Re: my b18b eg wont stay on without revvin it (wsiracerz)
when you give it gas, does it hesitate, or is it smooth? The sensor on top of the intake, is it on the TB? if it's the MAP sensor on the TB, that could be it. Wire it up and let us know.
Old May 25, 2004 | 09:48 AM
VtecDeMoN's Avatar
Have you tried adjusting the idler screw on the TB?
Brian
Old May 25, 2004 | 01:37 PM
wsiracerz's Avatar
Default Re: my b18b eg wont stay on without revvin it (VtecDeMoN)
yes i adjusted the idle screw, it is the sensor on top of the intake manifold, only comes on obd2 motors i think, its gonna get wired up today, we ll see if thats the prob or not
Old May 25, 2004 | 02:05 PM
VtecDeMoN's Avatar
As far as a plug on top of the manifold which one are you talking about, IE what does it look like? TPS? MAP?
Brian
Old May 25, 2004 | 02:09 PM
wsiracerz's Avatar
its on top of the intake manifold on the throttle body side of the manifold, it has one plug an one spot for a vacuum line, i will try to get pix up, also, i have a pr4 ecu, not sure if its obd1 or 0, will this matter at all?
transpar_nt
Dec 1, 2005 03:34 PM
rasinhell
Aug 15, 2005 02:50 AM
Magick211
Feb 4, 2005 11:42 AM
wsiracerz
May 25, 2004 08:40 PM
89JDMcrx
Aug 4, 2003 06:08 PM
