ef hatch w/ b18a swap...wiring plug Q's
i just put a b18a into a 90 civic dx. i have a si cabin harness and also si engine harness. there is a plug from the si engine harness that i don't know where it goes. its is 2 wires, blue and black with yellow stripe (its supposed to be behind block or around there). can anyone tell me where this plug goes. also there is a green plug on the b18a block, i believe it is the secondary temp switch (saw from previous posts), does that need to be connected. i havent got a ecu yet but i am putting a 90-91 ls ( same for the motor) and was just wondering if those things need to be hooked up so they won't throw any codes. any info greatly apreciated
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k5 »</TD></TR><TR><TD CLASS="quote">i just put a b18a into a 90 civic dx. i have a si cabin harness and also si engine harness. there is a plug from the si engine harness that i don't know where it goes. its is 2 wires, blue and black with yellow stripe (its supposed to be behind block or around there). can anyone tell me where this plug goes. also there is a green plug on the b18a block, i believe it is the secondary temp switch (saw from previous posts), does that need to be connected. i havent got a ecu yet but i am putting a 90-91 ls ( same for the motor) and was just wondering if those things need to be hooked up so they won't throw any codes. any info greatly apreciated
thanks</TD></TR></TABLE> HA HA I'm trying to find out the same thing on that 1st plug.
this one right? anyone that knows please tell us!!!!!
yeah thats the plug. are you using a 90-91 obd0 ecu too. did you wire up that green plug behind the block. if so can you tell me where it goes or does it throw a code. i thinking the wires might go to the purge valves next to the map sensor. is it giving you a code for not having it plugged up??
thecruzs2007@yahoo.com
Nov 22, 2011 11:57 AM
sonic47
13
Feb 10, 2010 03:23 AM
mike84 CRX-GTL
Sep 12, 2005 03:45 PM
wickedEFguy
Oct 29, 2003 09:10 PM
H22AEG2
Oct 17, 2003 08:36 PM
