Throttle body and Intake manifold for turbo?
Old May 24, 2004 | 09:32 PM
civic_hatchback's Avatar
Default Throttle body and Intake manifold for turbo?
This might get some flames but whats a good size throttle body to run if you are going turbo? Right now we do not have the money for a turbo so for the next month the throttle body will just be another part. i was also wondering about intake manifolds. Since we will be installing the Tb and IM without turbo, is there going to be a huge difference when we do install a turbo? This setup will be going onto a b16. Thanks.
Josh
Old May 24, 2004 | 10:08 PM
Default Re: Throttle body and Intake manifold for turbo? (civic_hatchback)
bump
Old Jun 5, 2004 | 01:21 PM
80884's Avatar
I was told that on turbo aplication...a bigger tb does nothing.
Reason for this is that if boost gauge reads off of your intake manifold and reads a constant 10psi, the intake is presurized what difference does a bigger tb make?
depending on the intake you pick...some will suck *** non turbo but will be great with turbo. I'm going with the victor x mani. venom is nice but it's like $300 more, i guess cuz it blings, idk. havent used either so i guess i can't compare them.
GSR-9
Jan 23, 2013 06:33 PM
TegraGsR
May 13, 2006 08:46 AM
1fastgsrturbo
Jun 23, 2003 03:21 AM
B16A1-EF9
Jun 10, 2003 11:50 AM
