Is thia a Xsi 92 or 92 b16 SirII motor??
Old May 24, 2004 | 08:41 PM
HATCHingMN's Avatar
Default Is this a Xsi 92 or 92 b16 SirII motor??
Hey guys I need help to identify my 92 JDM B16a motor....
It has a 9/2 stamp on the head and 5xxxx on the block??
could this be 92 a b16a sirI from the Xsi or 92 B16SirII from civic/del sol /crx??
help me I dont know much about JDM honda motors!!
How can I tell the difference between them two?? are they the same??
Modified by HATCHingMN at 5:53 AM 5/25/2004
Old May 24, 2004 | 08:47 PM
ricky1969's Avatar
Default Re: Is thia a Xsi 92 or 92 b16 SirII motor?? (HATCHingMN)
I know that if the digit is a 5 then you more then likely have a XSI engine. This of course may not always be true. If it is unmodifies look to see if it has two O2 sensors. If it does then you know it is a 1st gen engine. Late.
Old May 24, 2004 | 08:53 PM
HATCHingMN's Avatar
Default Re: Is thia a Xsi 92 or 92 b16 SirII motor?? (ricky1969)
anyone else??....
Old May 25, 2004 | 08:19 AM
jdmitr's Avatar
Default Re: Is this a Xsi 92 or 92 b16 SirII motor?? (HATCHingMN)
The one thing you need to remember is that if it is a B16 out of a 92/93 XSi it will be OBD1. Even though the trans is basically the same (Cable). The way to tell would be the JDM harness if you have it, by the style of plugs near the strut towers. From what I have seen the 92/93 XSi and the SIRII is the same engine!
Old May 25, 2004 | 09:06 AM
DB2GSR's Avatar
Default Re: Is this a Xsi 92 or 92 b16 SirII motor?? (b20civicvtec)
The difference between B16s is between 88-91 and 92-93, not whether it came from an Integra or a Civic. The transmissions however are different with the Integra being cable and the Civic being hydro.
Old May 25, 2004 | 11:11 AM
paybac4223's Avatar
Default Re: Is this a Xsi 92 or 92 b16 SirII motor?? (DB2GSR)
there really is no noticble diffrence....both have vtec bigger than dohc on the valve cover....both have nothing on the intake mani.... both have p30 pistons... my xsi came with a cable tranny and lsd... both put out 168ps.... the sir 2/ xsi does not have a thermo fan switch on the back of the block next to the oil filter like the 1st gens.... hope that helps...
Old May 25, 2004 | 01:13 PM
HATCHingMN's Avatar
Default Re: Is this a Xsi 92 or 92 b16 SirII motor?? (paybac4223)
Cool...thanks guys.
Are they both know as the 2nd generation B16 or is it just the one from civic sir??
