SRP B18c5 piston into B18c1 Block
Old May 24, 2004 | 07:55 PM
dsosa51's Avatar
Default SRP B18c5 piston into B18c1 Block
A local machine shop told me that the ITR pistons where to tall to go into a gsr block and they would stick out the top of me block. Is this true??
Old May 24, 2004 | 08:01 PM
m R g S r's Avatar
Default Re: SRP B18c5 piston into B18c1 Block (dsosa51)
NO.
Old May 24, 2004 | 09:41 PM
bubba your prison bitch's Avatar
Default Re: SRP B18c5 piston into B18c1 Block (m R g S r)
lol wtf? gsr and itr blocks are the same, itr just uses a worked head, IM and tb, ive got .25mm overbored jdm itr pistons in my gsr block
Old May 24, 2004 | 10:10 PM
IN VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsosa51 &raquo;</TD></TR><TR><TD CLASS="quote">A local machine shop told me that the ITR pistons where to tall to go into a gsr block and they would stick out the top of me block. Is this true??</TD></TR></TABLE>
With OEM pistons, the ITR pistons should have a taller compression height, but it's still not enough to get it above the deck unless it's been milled.
With aftermarket pistons, the blocks are considered the same, so the piston-to-deck height won't change, unless one of the blocks has had the deck milled.
Most of the aftermarket pistons I've seen seem to have .020" of piston-to-deck height built into the compression height. I really don't like that b/c then I would have to end up milling the deck .020" to get the 0.00" clearance I desire.
gator1
Feb 2, 2010 01:29 PM
wreckeddc4
Aug 20, 2007 09:30 AM
bon3z1201
Sep 26, 2006 01:51 AM
