88 tranny + clutch on 91 flywheel?
Old May 24, 2004 | 07:08 PM
orido 1.6's Avatar
Default 88 tranny + clutch on 91 flywheel?
Like the topic asks, is this doable?
Old May 24, 2004 | 07:18 PM
skip a stone's Avatar
Default Re: 88 tranny + clutch on 91 flywheel? (orido 1.6)
No clutch splines are different 88 trans smaller 91 trans bigger
88 flywheel smaller
91 flywheel bigger
not compatable
88 trans must use 88 flyhweel clutch and pplate
Old May 24, 2004 | 07:50 PM
tilt's Avatar
Default Re: 88 tranny + clutch on 91 flywheel? (skip a stone)
what makes the 91 flywheel not work with the 88 clutch and pressure plate?
i thought the 91 flywheel just has a larger surface area. the 88 clutch disc uses a smaller surface area, so i dont see why it wouldnt work.
Old May 25, 2004 | 08:16 AM
jlicrx's Avatar
Default Re: 88 tranny + clutch on 91 flywheel? (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">what makes the 91 flywheel not work with the 88 clutch and pressure plate?
i thought the 91 flywheel just has a larger surface area. the 88 clutch disc uses a smaller surface area, so i dont see why it wouldnt work. </TD></TR></TABLE>
the pressure plate mounting holes on the 91 flywheel have a larger diameter bolt circle than the 88 pressure plate
Old May 25, 2004 | 09:47 AM
tilt's Avatar
Default Re: 88 tranny + clutch on 91 flywheel? (jlicrx)
thanks
Old May 26, 2004 | 12:35 PM
orido 1.6's Avatar
ah, arg, that ruined my day...
Old May 26, 2004 | 12:36 PM
orido 1.6's Avatar
thanks guys
Old Jun 6, 2004 | 12:27 AM
4potnick's Avatar
I have 90-91 clutch and flywheel on 88 or 89 tranny. works no problem.
Old Jun 6, 2004 | 12:45 AM
shorte's Avatar
Default Re: 88 tranny + clutch on 91 flywheel? (4potnick)
some can be mixed and matched
21 spline 190mm came in 88 crx/civics
21 spline 200mm came in 86-89 teg/79-87 prelude
20 spline 200mm came in 89 crx/civics
20 spline 212mm came in 90-00 non-b series crx/civics
21 spline 212mm came in 84-87 2.0L Preludes
hatchet_honda
13
Nov 6, 2010 12:15 PM
ParistsCP
Oct 7, 2008 06:59 AM
agendadjs
Dec 8, 2007 04:56 PM
CoreyR
Jan 18, 2006 07:18 PM
carsaregood
Jul 31, 2002 08:25 PM
