vtec pressure switch problems
ok im runnin a jdm b16a in my crx, jdm pw0 ecu w/ hasport vtec subharness
since ive installed the motor ive gotten rid of 3 codes but im left with the 22. Ive got a not TOO crazy dent in my oil pan. When i start the car on the code begins within 3-5 seconds of ignition...does this sound like a result of the dent? bad wiring? or a problem with the switch itself?
i see alot of people having the code pop up after hard driving in my search, but mine pops up almost automatically everytime, even after i reset the ECU
also when i unplug the plug that goes into the oil pressure switch the idle decreases to like 250rpmish...is this normal?
Modified by X-Static at 8:27 PM 5/25/2004
i did...ive double checked the wiring, and the fact that the idle changes when i unplug the sensor from the switch makes me believe the wiring is fine, does this sound true?
i have the same code....i have tried 2 oil switches from vtec accords and the same code. but the accord switches are grey and my car is green. the honda dealer said that the accords are differant. so i just found another vtec sol. i have not received it yet ,but when i get it i will let you know if it works.
Travis R
11
Jul 23, 2011 06:04 PM
Kaleb
Dec 16, 2009 03:56 PM
