Suspension Questions
Old May 24, 2004 | 06:44 PM
chill00lude's Avatar
Default Suspension Questions
Hey guys i just got tein basic dampers for my 00' prelude, i am a little unsure about what to do on the install. Is it a difficult task or fairly reasonable, any tips about installation?
Old May 24, 2004 | 07:26 PM
Teglessb18's Avatar
its fairly reasonable id say ive done like 4 installs
Old May 24, 2004 | 08:00 PM
AndyD's Avatar
Default Re: Suspension Questions (chill00lude)
Mine was pretty easy on my 92 Si. Taking out my OEM suspension was a little tedious. The ball joints were the most time consuming. All it takes is a little creativity and a ball joint separator tool.
Putting the suspension back together is easier.
I actually JUST FINISHED insalling my suspension. I need to raise the rear a little.
Good luck.
Old May 24, 2004 | 08:57 PM
dawalude's Avatar
if you havent done any suspension work on a prelude before, i'd suggest having someone do it for you (not neccessarily paying a shop to, but maybe a friend who has done suspension work). out of all the hondas i've worked on the prelude suspension is the most difficult thus far. you will definately need a spring compressor to take out the stock compression. its difficult without it. when installing the basics, for the easiest installation make sure its set to the lowest height, that way it just slips into the wheel well with no problems. after its in, then adjust the height accordingly.
hey AndyD, why did you have to remove the ball joint to take out your rear suspension? i've worked on a 4th gen and my 5th gen and never had to do that. what do you speak of? just wondering
Old May 24, 2004 | 09:10 PM
AndyD's Avatar
Default Re: Suspension Questions (dawalude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawalude &raquo;</TD></TR><TR><TD CLASS="quote">
hey AndyD, why did you have to remove the ball joint to take out your rear suspension? i've worked on a 4th gen and my 5th gen and never had to do that. what do you speak of? just wondering </TD></TR></TABLE>
I have NO IDEA how you were able to get your shocks off without detaching the ball joint. Were the shocks you took out OEM?? Aftermarket??
I tried and there was NO WAY I could get them out. Here is a writeup of how to install shocks on a Prelude. They say you have to too. I tried not taking out the joint and it was impossible.
As for Prelude suspensions being harder than other Hondas. I don't know if that is true either. I helped my friend do his Integra AND Civic and it was the SAME EXACT procedure.
http://www.ntpog.org/mods/fift...shtml
Old May 24, 2004 | 09:32 PM
dawalude's Avatar
Default Re: Suspension Questions (AndyD)
the procedures are the same but me, as well as others, have had problems taking out the rear suspension (OEM suspension, its easier with aftermarket).
as for ball joint removal, yeah i never have to remove it. which is probably why i have a harder time than you in removing the OEM suspension
in the integs/civics/accords i can push down with my foot on the rotor and can remove the suspension. in the lude, i can have 2 people pushing down and there still isnt enough clearance to take out the suspension
Old May 25, 2004 | 08:11 AM
Teglessb18's Avatar
ya it is probably easier if you remove the ball joint it isnt very hard either.
Old May 25, 2004 | 10:17 AM
OTT's Avatar
OTT
Ok dawalude what you said doesnt seem to coincide with other things youve said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawalude &raquo;</TD></TR><TR><TD CLASS="quote">...hey AndyD, why did you have to remove the ball joint to take out your rear suspension? i've worked on a 4th gen and my 5th gen and never had to do that. what do you speak of? just wondering </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawalude &raquo;</TD></TR><TR><TD CLASS="quote">the procedures are the same but me, as well as others, have had problems taking out the rear suspension (OEM suspension, its easier with aftermarket).
in the integs/civics/accords i can push down with my foot on the rotor and can remove the suspension. in the lude, i can have 2 people pushing down and there still isnt enough clearance to take out the suspension </TD></TR></TABLE>
can you explain what you mean?
Old May 25, 2004 | 10:43 AM
mike640's Avatar
Default Re: Suspension Questions (OTT)
You don't need to remove the ball joints in the front, but the ones in the rear are very hard to get out unless you remove the joints.
Old May 25, 2004 | 12:43 PM
thanks
Old May 25, 2004 | 01:50 PM
purplepassiongsr's Avatar
yes, u will need to pop a fairly large boner to install this particular tein kit. i believe it is an easy install if you stay focused and keep your eye on the prize, which is to get LOW...
Old May 25, 2004 | 02:02 PM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OTT &raquo;</TD></TR><TR><TD CLASS="quote">Ok dawalude what you said doesnt seem to coincide with other things youve said
can you explain what you mean?</TD></TR></TABLE>
I have no idea what he is talking about either. I installed a suspension of both a 4th Gen and a 5th Gen. I HAD to take the ball joint off both times. There was NO WAY around it.
Having people stand on the spindel down't sound like a good idea in the first place.
Old May 25, 2004 | 07:59 PM
Teglessb18's Avatar
well purplepassiongsr i heard that u have to do that but u must have ek in the backround with a prince greed face putting on his new carbon fiber rims
Old May 26, 2004 | 06:58 AM
so do you have to remove the ball joints or no?
Old May 27, 2004 | 07:14 AM
aschue's Avatar
Default Re: (chill00lude)
I had to when I did mine.... Actually my SH required removed a front lower ball joint as well. Don't worry, it's really not that hard. Just use the tool shown in the writeup at http://www.ntpog.org/mods/fift...shtml and you can get it off in 2 minutes. You can get one for like $6 at harborfreight. http://www.harborfreight.com/c...36861
sixfiveoh
Nov 12, 2006 10:40 PM
MyEG6
Jul 31, 2005 03:59 PM
iris
Oct 25, 2004 01:17 PM
Flux
Dec 1, 2003 04:11 PM
