eg6 won't start
i can't figure this out, my car won't start, it turns over but its like its not getting gas, i already replaced the distributor
, and i also made sure the timing was dead on. I noticed that sometimes the fuel injectors won't come on it sounds like (b.c u can usually hear them fuel up) and when they don't it won't start, if they do it does for the most part but sometimes doesn't. Fuel pump maybe? any info would be greatly appreciated thanks alot guys.
and are u getting spark? check the wires. i had the same problem, right before i launched vs a camaro haha my car shut down. i felt like a moron, but it was the distributor..........and many "stupid ricer" comments arraised bc of that. so dont feel so bad, anyway since u changed it it may not be that, did u change the cap?
thanks for the info, i also checked the ground wiring, it was one of the first things i checked, anyone else that has had this problem and fixed it please post, i'd really appreciate it alot. thanks in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonny G. »</TD></TR><TR><TD CLASS="quote">Could be a faulty main relay.</TD></TR></TABLE>
check this its common
im goin to kick myself in tha *** for asking this but where is the main relay located,
also how do i check if its faulty or not?
thanks in advance.
thanks in advance.
ive had this prob too...
when you sit in the driver's seat(if youre in the usdm vers.
), it will be a 1"x1" box next to your left knee under the dash. an easy way to tell if it could be the relay is crank the car and tap the relay. if it starts then its def. the relay. it took me weeks to figure it out. thanks to HT
stdefhatch
May 6, 2006 01:54 AM
