How to swap?Steps?
Old May 24, 2004 | 02:27 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default How to swap?Steps?
What are the steps no one is telling me for baic swaps steps like im doing a itr in a crx and no one respawned i nead the steps i had a website but lost it!!!
Old May 24, 2004 | 03:12 PM
brisk's Avatar
Default Re: How to swap?Steps? (CrxStreetRacer)
hahaha are u 16 or what?
Old May 24, 2004 | 03:22 PM
Full Race A6's Avatar
Default Re: How to swap?Steps? (brisk)
^^ ahah are you a noob or what
But seriously, beyond the fact that Brisk is a bitch
A b18c5 swap into a crx is not an easy swap, d series swaps are easy
Old May 24, 2004 | 03:47 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: How to swap?Steps? (W O T)
lol ya i know but i want to do it
Old May 24, 2004 | 04:07 PM
You already have a gsr motor? Why not boost it? Spray it?
Old May 24, 2004 | 04:20 PM
FastAllmotorLsVtec
Guest
Posts: n/a
sry dude i want to be allmotor see what times i get then go from ther can some help me with the steps after battery disconnect and harness
Old May 24, 2004 | 04:23 PM
Nocturnal_Lude's Avatar
you gotta be kidding right?
91civicEX's Avatar
where in the bay area are you? i might be able to help depending on where you are. just start disconnecting things that are connected to the engine. then when its out start preppin the b18. put the harness on it. i dont know about b series but i leave the mounts and everything on too. it might be a little easier without the intake manifold. have you done any other engine work before?
Old May 24, 2004 | 04:24 PM
Default Re: How to swap?Steps? (91civicLX)
if youre going all motor why not go ls/vtec or h22, start with a better less overpriced swap
Old May 24, 2004 | 04:30 PM
FastAllmotorLsVtec
Guest
Posts: n/a
i was alos thinking about h22 they pull pretty hard but their hella heavie can take turns at 50...
ive dont this before with two friends and just need stop good stteps and tips...
Old May 24, 2004 | 04:40 PM
common misconception about h22s
Rear 2point2's H22 swap thread, very detailed and describes how bullshit the heavy motor affecting handling is
Old May 24, 2004 | 06:10 PM
tolnep's Avatar
how bout this?
http://www.gsport-online.com/P...D=730
Old May 24, 2004 | 06:21 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: How to swap?Steps? (tolnep)
funny u drop that link i was looking for the engine all over that site to day thanks!
Old May 24, 2004 | 06:24 PM
BioXide02's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrxStreetRacer &raquo;</TD></TR><TR><TD CLASS="quote">lol ya i know but i want to do it</TD></TR></TABLE>
Whaa? In another thread you said you allready had this swap done and such..
Old May 24, 2004 | 07:14 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: How to swap?Steps? (BioXide02)
what thread i never said i did maybe u got confused with my b18c1 i did
Old May 24, 2004 | 07:24 PM
BioXide02's Avatar
Soo you put a b18c1 in your car.. yet you need help with pretty much the same swap?? WTF
Old May 24, 2004 | 07:30 PM
FastAllmotorLsVtec
Guest
Posts: n/a
dude ok i did it with some friend who are a little smater than me this time i plan on doing my self
Old May 24, 2004 | 07:38 PM
gonna be a $3500 learning experience
waste of money for sure, thats what friends are for
Pick up a book and read, built that motor
Old May 24, 2004 | 08:07 PM
FastAllmotorLsVtec
Guest
Posts: n/a
jeez ppl i know but where can i get a book i been lookig all over the net!
Old May 25, 2004 | 01:11 AM
909rex's Avatar
check HAsport they can probably help you... your gonna need new mounts, VTEC ecu, shift linkage, and axels (not sure if you got those already)... give them a call i bet they will help you out to the fullest... dont listen to most of these idiots on H-T that are only here to flame people who need help, to try and make them selves all high and mighty...
Old May 25, 2004 | 03:21 AM
kshymkiw83's Avatar
Well an ITR swap into a CRX......
Motor
New Axles
B-Series Mounts
ECU......you will have to convert your Engine to OBD-1 or your car to OBD-2
Steering Knuckles
Tranny
And replace the common things on the motor you will need to replace.
I thought about this swap, and if you buy the motor from HMO (4500) then the swap is going to cost you close to 7 grand, done correctly. For 7 Grand you could build your C1 or even a H22 and get better results than placing a stock C5 into your engine bay.
IMO a C5 swap is overrated for the EF, unless you had a ITR, and wrecked it, or get the engine for 3 grand or less
Old May 25, 2004 | 07:05 AM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: How to swap?Steps? (kshymkiw83)
thanks guys
dont acted smart if you see me in your rear mirror lol ill smoke you haha.
But i plan doing this month prolly next cause im going to dc and then i want some dyno numbers so i take it some where...
Old May 25, 2004 | 08:19 AM
I3ackfire's Avatar
Sounds like something one the cast members would've said of the F&F ......
Old May 25, 2004 | 09:08 AM
manson's Avatar
LMAO... but if you break you won't be able to fix it...
do your homework. instead of posting about i need help you should have been searching... do you know how many archived posts are about this very same topic? you have almost 500 posts and you haven't figured out how to search on HT yet?
best of luck to you... i say you should have that shop :cough: i mean those friends help you out again...
good luck
Old May 25, 2004 | 10:49 AM
kshymkiw83's Avatar
Default Re: How to swap?Steps? (mansonteamsmyt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mansonteamsmyt &raquo;</TD></TR><TR><TD CLASS="quote">
good luck </TD></TR></TABLE>
I agree with the "not being able to fix it part"
It seems you have a decent platorm to start from if your mods are, C1, Crower Cams, AN-R Header, and a Venom Intake Mani. Spend that 7grand into that Engine. Go to the All Motor forum and ask some of those guys how to build a strong C1 on 7 grand. I guarentee for 7 grand you could have a all motor beast of a C1
