Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Overheating in turns
Old May 24, 2004 | 02:22 PM
all stock's Avatar
Default Overheating in turns
Like problem stated.
Mods:
CnR Radiator
Mugen Thermostat
Mugen Fan switch
Went to streets of willow yesterday, after about 3-4 laps, the temp needle starts to climb. I notice it most in the middle of a turn, while going straight it starts to cool down. Normal driving is fine. Any ideas?
Old May 24, 2004 | 02:55 PM
Bones Barry's Avatar
Default Re: Overheating in turns (all stock)
How high does your temp needle climb? might not be accurate ... just a thought.
Old May 24, 2004 | 08:00 PM
all stock's Avatar
Default Re: Overheating in turns (ChrisOnePointSix)
7/8's of the way up.
stock is 1/2.
i'm sure if i keep on driving it would of went higher.
Old May 24, 2004 | 08:27 PM
tnord's Avatar
how warm was it yesterday?
Old May 24, 2004 | 11:28 PM
all stock's Avatar
Default Re: Overheating in turns (tnord)
high 70's with 33mph winds.
i've never had the problem at other track i've been to. back in february, i was running buttonwillow no problem.
Old May 25, 2004 | 04:11 AM
MattD@Stoptech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all stock &raquo;</TD></TR><TR><TD CLASS="quote">Like problem stated.
Mods:
CnR Radiator
Mugen Thermostat
Mugen Fan switch
Were any of the mods done recently? Did you properly bleed the system? Check the water level?
Old May 25, 2004 | 10:04 AM
duh blacksheep's Avatar
Default Re: Overheating in turns (El Pollo Diablo)
maybe the speeds on a turn is slower so it cools less...but thats probably unlikely
it might be your water pump? i dont know what revs you have during a turn
Old May 25, 2004 | 10:14 AM
tnord's Avatar
Default Re: Overheating in turns (duh blacksheep)
if it was the water pump i would think that the car would be hot all the time, unless it's just a blade or two that has broken off.
i would be tempted to say thermostat on this one. take it out, put it in a cup of boiling water, and see if that bitch opens up like it's supposed to.
Old May 25, 2004 | 09:22 PM
all stock's Avatar
mods were done about 6 months ago. i've done streets before and had no problem. then buttonwillow in feb. the system has been bled.
i'm going thru the turns at about 7k rpm modulating throttle.
damn, i just got the damn thermostat, i hope it hasn't failed on me already.
Old May 25, 2004 | 09:42 PM
tnord's Avatar
at least it's easy to check.
does it overheat on the street as well? if so, pull the thermostat out and see how that works.
Old May 25, 2004 | 10:11 PM
all stock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnord &raquo;</TD></TR><TR><TD CLASS="quote">at least it's easy to check.
does it overheat on the street as well? if so, pull the thermostat out and see how that works.</TD></TR></TABLE>
normal driving is fine.
Old May 26, 2004 | 09:41 AM
JDMTYPER's Avatar
I am having the same problem. Anyone have a solution? Same thermostat and fan switch here as well.
Old May 26, 2004 | 10:08 AM
Default Re: Overheating in turns (JDMTYPER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMTYPER &raquo;</TD></TR><TR><TD CLASS="quote">I am having the same problem. Anyone have a solution? Same thermostat and fan switch here as well.</TD></TR></TABLE>
maybe you answered your question .... could be the Mugen thermo and / or fan switch ... just a thought.
Old May 26, 2004 | 10:27 AM
Littleton's Avatar
I had the same problem but with the Spoon switch and themostat. I switched them both out with the stuff from Autozone and I haven't had any issues for a year now.
Old May 26, 2004 | 11:28 AM
all stock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisOnePointSix &raquo;</TD></TR><TR><TD CLASS="quote">
maybe you answered your question .... could be the Mugen thermo and / or fan switch ... just a thought. </TD></TR></TABLE>
i've driven on tracks previously, and no harm was done. why now?
Old May 26, 2004 | 11:46 AM
tnord's Avatar
i've driven on tracks previously, and no harm was done. why now?</TD></TR></TABLE>
because stuff breaks.
Old May 26, 2004 | 11:56 AM
driftin4's Avatar
streets has pretty slow corners and the engine is working real hard in them.. (more like an over grown auto cross with a big straight)
The corners do not provide the best air flow...
have you tested your fan on temp? If the fan is pulling when it is needed then air flow is not the problem.. As long as the fan is properly shrouded..
I would then try to verify that the engine is really getting hot and its not a gauge acting up under the g-forces...
I had massive temp issues when we took the cossie down to Streets for the G-Games... It didn't help that it was 108 with a track temp of 145ish...
Old May 26, 2004 | 12:05 PM
tnord's Avatar
Default Re: Overheating in turns (driftin4)
the fan isn't doing anything but getting in the way at speeds above 15mph.
Old May 26, 2004 | 01:48 PM
Steppin Razor's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnord &raquo;</TD></TR><TR><TD CLASS="quote">if it was the water pump i would think that the car would be hot all the time,</TD></TR></TABLE>
Not necessarily. When the water pump in my 84 wagon went, it would only get hot when idling.
The first thing I thought of was the levels + bleeding the system since it only happens when turning.
Does it overheat just idling?
Old May 26, 2004 | 03:40 PM
all stock's Avatar
Default Re: Overheating in turns (Steppin Razor)
idles just fine.
Old May 26, 2004 | 03:58 PM
tnord's Avatar
can you please check the thermostat........it takes 2 minutes, then we can move on from there in trying to figure out the problem.
Old May 29, 2004 | 10:48 AM
all stock's Avatar
got to test it this weekend - it opens.
Old Nov 24, 2004 | 08:26 PM
all stock's Avatar
problem is still there and i've attempted to track it. get about 3-4 laps before I have to pit because my needle is 3/4 of the way up.
i have a vtec solenoid gasket leak and the dirt was caked all over the CTS. Could these two problems affect temperature that much? Fan's usually runs for 15 minutes straight after 3-4 laps.
Installed a water and oil temp gauge. Going to see from there if it's affected during street driving.
Old Nov 24, 2004 | 08:27 PM
all stock's Avatar
Oil Temp can rise up to 95 C on the street, right? I've never seen it go over 100. Just on the freeway around 4.5krpm
Old Nov 26, 2004 | 12:39 PM
all stock's Avatar
Please help solve my problem.
I've stumped everyone that I know - this includes shop owners and master mechanics.
